Burn-out Technique for a TH400??
We're taking Ellen's '60 Catalina out to the track for a few test passes Saturday night and I need to know the recommended technique for doing burn-outs with a TH400 without messing it up. Here are the specs: the transmission is a standard, nothing special Hughes street/strip TH400 with a standard valve body. The rear end is 3.90 to 1 posi unit. The car has a Line-loc to lock the front brakes for the burnout. It's a very mild car that will run low 14's at best in the Tucson heat, but it does have slicks and I want to do a burn-out prior to making passes. Regardless of the floor shifter position, the trans will start in 1st gear. I can hold it in 1st, second or drive, but it will always start in first, shift to 2nd and then to drive (depending on shifter position). In other words, I can't start the burn-out in 2nd gear or high gear, only in 1st gear. What is the best way to do the burn-out?
Thanks. Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
Here is what I was told to do and I did it for 1000+ passes w/no problems.
Its easy w/linelock. The idea is to get it to 3rd gear under low power then roll the throttle on. Let the car start walking forward and let off the gas so its not under power when the car hooks up. In other words, let off the gas while tires are still spinning. Don't try to drive through. |
I would always start the burnout in 2nd gear and quickly shift to 3rd as soon as I could feel the rearend up on the tire.
1963 Tempest Convertible Pontiac-Powered Funny Car: 400 block, Littlefield 8-71 blower, Enderle injection, custom blower intake, three-disc glide clutch, three-speed Lenco |
I have had very bad luck with th400 and spags.........consequently, I will only do 1st gear burnouts with an Automatic valve body.....saves the sprag....
Never had sprag issues with stockish power tho......so your mileage may vary..
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile |
With my old set up with forward shift pattern and beefed up street guts I would just leave it in Drive.....going to do it's own thing anyhow unless you start in L or 2nd..
In Drive it was easier to snag neutral after burn out....
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
Does it need a burn out since its stock running low 14's? If it will hook with out it don't waste the rubber!
I always started in 1st and shifted fairly quickly into 2nd and then third.
X2 that's how I do mine.
Thanks for all the replies. I think I'll just stick the shifter in "D" and let it shift to high under low power. I'm not planning heavy-duty burn-outs (I've got my '63 for that), but just enough to dry off the slicks after driving through the water box. Driving around the box is a big pain at our track. I would do a first-gear only burnout, but I don't think I'd get enough wheel speed with the 3.90 rear end.
We'll see how it goes. After I figure it out, I get to teach Ellen . Jim
With full auto vb, hold in low and keep rpm below governor so it wont shift up on its own. When it starts to push out ease off pedal and drive to line.
Jim said it's a stock valve body. Will start off in first gear no matter shifter gear selection.
Just saying. FWIW: I did have the upgraded sprag & soft parts in tranny.
ASAP to high gear...
*** THE BIG BRACE is here *** |
I had a 34 element sprag put in it, and it's been fine since. Many 1/4 mile passes on the TH400 and now it's in my heavy Bonneville wagon without issues.
Darin '64 Bonneville Wagon (sold) 69 Lemans-All motor (sold) 9.81 @ 136.39MPH |
Honestly,seeing as I DIY all my own transmissions,if I were going to run an OE style auto valvebody (w/no manual low control),then I would'nt even bother with the 34 element sprag @ all,I'd just leave the roller style intermediate sprag in there and drive it like I stole it.
IMO under say 500 or so hp the OE roller style sprag is probably just as reliable as the "dogbone" style sprags are. Anyhow,the general "rule" holds: High gear only = best B/O method. 2nd quickly into high = next best B/O method. And when neither of those is an option... Low gear only = also an acceptable B/O method. Anytime you make a 1-2 shift during the burnout it's very hard on the intermediate sprag. So is pedaling the car hard in second gear,that's another cause of a fair amount of rolled sprags. HTH Bret P. |
Just drive around the water box, low 14's and slicks? No reason to do a burnout other than to just have fun. It might be embarrassing if you do a big ass burn out then run a 14 ET, or you might stall the engine when it shifts into 3rd gear, or they might just think your having engine problems when they see your ET. Don't think your making enough power to hurt a TH-400 so I wouldn't worry about it. Just go and have fun.
Tim Corcoran |
Jack Ferris RestoRacing LLC www.restoracing.com Sandy, UT --------------------------------------------------- |
Jim
I have to admit burnouts are fun, only thing more fun is lifting the front wheels in the air.
Tim Corcoran |
+1!!!
1964 GTO 501, Edelbrock Heads NA, 3460 lbs. 9.76 @ 137mph 1971 Trans Am Lucy Blue, 11.56 @ 115 1966 LeMans. 462, SD prepped Kaufman D ports. 11.90 @ 112 1976 Trans Am twin turbo 462, SD Edelbrock heads 8.50@159 2009 G8 GT |
My opinion why you only want to do a 1st gear burnout with a standard valve body.
Think about it. With manual valve you have control of the transmission and can gently start in first, roll right thru 2nd and into third. With a standard valve body, the trans decides were it wants to be. Just because you throw it into third like many have said, doesn't mean that is were it's going. Especially with the kick down hooked up you may find yourself in second, even after shifting into third and that's were you don't want to be. Want that tranny to live a long life, roll thru the water, stay in first below the rpm were the trans will auto shift to second and do your thing. |
