| Pontiac Business Entities Exchange Sources, Compliments and Grievances in regard to Pontiac parts or services rendered by an individual or business. |
Just wanted to give a thumbs UP to Right Stuff Brakes.
I had been stuck trying to figure out how to finish my front disk brake setup on my 1966 GTO. With the "Z-Bar" in place, I could not get the rear brake line to install into the rear of this block. This was with parts from the "other" more well known brake line company I.T.. Called Right Stuff and they sold me a disc brake conversion kit which bypasses the distribution block all together. Everything was labeled and in plastic bags with instructions. So over the weekend I installed the kit and now I have a nice upgraded brake system on a car that I havent driven since 1999!! Don
1966 GTO 1966 421-10.1-1 comp-Race Tec 23cc Pistons KRE Tri-Power KRE 65cc Aluminum Heads XE274 cam by Comp Cams DUR 230 Int 236 Exh @.050 - 110 LSA LIFT .491" Int .491" Exh Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers 1966 Muncie Wide Ratio 4-Speed 1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears |
I have to give them a thumbs up too.
A few years back when I was restoring my GTO I bought some brake lines from the at Englishtown. I didn't install them till almost a year later and the weren't quite correct. I spoke to them the following year at Englishtown expecting to buy the correct lines and the were given to me for free on the spot. I didn't have the first set to exchange and they told me not to worry. The new set fit perfectly. |
They are a good Co. they know their stuff very well .
