OK guys the frame has 1-1 1/4" square hole in it for the bushings.The 1/2 bolt has a lot of room there. Are the perfectly centered? Mine seem to be offset bu the body panels seem to line up good.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
My brother has his 73 Camaro in a body shop at moment.
Has a bunch of "import" sheet metal on it. The import stuff has made it a challenge, but theres SO many issues w/ the O.E. parts, it's pathetic. Many things have to be adjusted to get body lines tighter than original. The body guy is a seasoned pro, and friend. He said "F" bodies can be difficult....who knows. From all I've seen on this Camaro, IF, IF, it lines up, count your blessings, carry on !!!
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down...
