Old 10-08-2014, 12:16 PM
boodlefoof boodlefoof is offline
Default '63 4 cyl 4bbl engine and header
I have a partially disassembled 4 cylinder 4 barrel carb engine taking up space in my garage. It came with my project car and was still assembled and most of the openings were capped/plugged/taped when I bought it, but I've since pirated a few pieces from it here and there. It has been kept in my garage since I got it. I haven't opened it up any more than what you see in the pics, but based on the paint and level of cleanliness of it, I'd guess it was rebuilt at some point. I'd love to see someone have it who will use it. I also have the exhaust header for it.
The engine code is "77Y" and the date code is "E163." Under the engine code is "488126" and off to the left side of the front of the block is "55567" - not sure what that is. The head casting number is "543797."
$100 takes it, but you have to come get it. I'm not interested in shipping it and would rather not part it out any more.
PM me if interested.
Name:	engine front.jpg
ID:	378268   Click image for larger version
ID:	378269   Click image for larger version
ID:	378270   Click image for larger version
Old 10-08-2014, 12:35 PM
charlie66's Avatar
do have a pic of the driver side of the block so I can see what block it is.... If its the block I think it is , ill buy it....
Thanks..
My Half AN Injun.....
Old 10-08-2014, 01:00 PM
Here is a picture of the driver's side and of the back. Let me know if you need any better pictures. My camera isn't great, but I'll do what I can.
ID:	378272   Click image for larger version
Old 10-08-2014, 03:35 PM
charlie66's Avatar
Its the thin block. Too bad.. If I lived closer I would still buy it for the parts. I would love to have that timing chain and tensioner.. : )
Thank you for the extra pictures...
Old 11-09-2014, 05:39 PM
Bump. Still available.
Old 11-10-2014, 07:19 PM
Chiefkey Chiefkey is offline
Default 63 4 cyl 4bbl engine and header
Just curious...what do you mean by "Thin Block"? Ate there difference in the castings for the 4 cylinder blocks ?
JK
Old 11-10-2014, 07:22 PM
Default 63 4cyl 4bbl engine and header
By the way... I think I ran across a NOS tensioner on Ebay recently. May still be there.
