Old 10-13-2014, 08:19 PM
lazlo's Avatar
lazlo lazlo is offline
Default 2007 Denali front airbag sensor code.
Got an airbag code today. Scanner says the code is B0084. Front impact senor #2.
85 bucks a piece... So, can I use a used sensor. Is there any reprogramming that needs to be done? and which one is sensor #2
[SIGPIC][/SIGPIC]
http://www.gogtoaa.com/leibys%20rides.html
Old 10-13-2014, 10:36 PM
lazlo's Avatar
So I'm reading on line that this code may also be caused by broken wires under the front seats. Cleaned the truck the other day and ran both front seats all the way to the rear then all the way to the front to vacuum.
I guess tomorrow I check the wires under the seats and clean the connectors on the impact sensors and see if the code resets..
[SIGPIC][/SIGPIC]
Old 10-15-2014, 09:34 PM
lazlo's Avatar
Right Front impact sensor (#2, pass side), purchased at OReilly's for $85 bucks. Remove key from ignition. Pull the airbag fuse, raise the front end a little to make it easier. 10 mm wrench to take it off the core support, a screwdriver to pop the clip & the plug out. Install the new unit & replace the 15 amp airbag fuse. Start the truck and the code should be clear..
[SIGPIC][/SIGPIC]
