Old 10-17-2014, 04:36 PM
Nitebird Nitebird is offline
Default Dougs headers and dipstick tube for Pontiac 455 or 400....
I was fitting my Dougs headers onto my engine (Pontiac 455 with Edelbrock D Ports) just to see if they would clear everything. I noticed that the dipstick tube is going to interfere with the header flange that runs between each set of tubes.
What did you guys do to make it fit or did yours even come close to the flange?
Old 10-17-2014, 04:52 PM
66bonne's Avatar
66bonne 66bonne is offline
What year/model Poncho ? Stock oil pan ?
Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8.
Old 10-17-2014, 04:53 PM
Jim
1975 Pontiac 455. It has the stock oil pan and dipstick.
Old 10-17-2014, 06:48 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
You either bend the tube out some and the flange fits behind or you cut the flange out between those tubes.
Skip Fix
Old 10-17-2014, 06:56 PM
Yep that's what I thought.
Old 10-17-2014, 07:12 PM
chrisp chrisp is offline
Tight but fits .
Old 10-17-2014, 09:08 PM
Originally Posted by chrisp View Post
Tight but fits .
Yeah the flange is really thick so I have gotta bend it a little.
Old 10-17-2014, 10:42 PM
Doug Hopkins's Avatar
Doug Hopkins Doug Hopkins is offline
I grinded a notch in the flange and kept the tube straight.
Old 10-18-2014, 03:18 PM
Gerrit's Avatar
Gerrit Gerrit is offline
I bent the tube down just a bit.
Old 10-18-2014, 11:07 PM
Firebob's Avatar
Firebob Firebob is offline
Oh sure, easy to do on the stand in the garage! LOL. Not so easy on the car. It's a b!tch but doable. I think I had to unbolt the MM and lift the right side up a bit. Just could reconsile grinding/cutting on the ceramic coated, way expensive, headers.
Robert
69 Firebird-462/Edel round ports/currently running the Holley Sniper/4sp/3.23posi/Deluxe Int/pwr st/vintage air/4wl disc( a work in progress-always )
http://youtu.be/eaWBd3M9MN4
