Old 11-05-2014, 06:52 PM
lucky1 lucky1 is offline
Default 65 wiper grill foam pads.
Can someone tell me where those foam pads go for the cowl grill ?
Old 11-05-2014, 07:37 PM
Jeff Hamlin's Avatar
Default L&R side of the upper cowl
If you look at the upper cowl under the grill you'll notice raised portions that the insulator should be set into.
3M black weatherstrip adhesive can be used to hold them down in-place.
Old 11-05-2014, 08:37 PM
Thumbs up Wiper grill pads
Thank you.
Old 11-05-2014, 09:17 PM
GT182's Avatar
GT182 GT182 is offline
Make sure you glue them in the right place. When the cowl is installed you can't see them if they're installed in the right place. Outside of the last slit in the cowl towards the fenders.... under solid metal.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
