Yet another question. Do the mounting bolts get a washer when installing 65 grills ? Tks.
mine has washers.
A good rule of thumb is that any hole that is slotted or oversize should get a flat washer or a bolt with washer attached. Slotted holes and oversize holes were used to allow wiggle room when fitting parts together. . Last edited by Zimtok; 11-10-2014 at 10:08 AM. |
I've got washers on mine. It's a good idea to do.
originally did not have any washers,
1967 RAM AIR GTO 1 OF 156 AUTOMATICS |
As mentioned above, no washers were used from the factory
www.69judgeregistry.com Documenting ALL 1969 Judge and Ram Air GTO cars. If you have one of these cars we would love to hear from you |
No washers may have been used at the factory but did the original bolt have a head that served as a flat washer?
If he doesn't have the original factory bolts he may want to use washers. . |
Here are the correct bolts. Notice the self threading tips.
can't think of any body bolts that the washers were not integrated to the bolts if used . my car is on a lift close to me all day LOL |
Here is a pic of head. These very well may be cadmium plated not phosphate.
dld,
You are correct that is the bolt used to mount the grills, and although you are only showing the bottom bolts it is also what was used on the top. There were no slotted/over sized holes used on the sheet metal (top or bottom) for mounting the grills so therefore no washer is needed. Although on my (non-original) car I found the bolts that had a slight flange head. They almost look like an oil pan bolt. . |
Thanks for the help.
I for 1 feel well payed ...your welcome!
