Old 11-20-2014, 08:49 PM
lazlo's Avatar
lazlo lazlo is offline
Default 1966 Console piece
The console on my 66 GTO is missing the small latch adjustment piece. Anybody have one they want to part with or can someone post a picture of one so I cam make a copy?
Name:	latch sized.jpg
[SIGPIC][/SIGPIC]
http://www.gogtoaa.com/leibys%20rides.html
Old 11-20-2014, 10:50 PM
xgoater's Avatar
xgoater xgoater is offline
Unfortunately you are not missing a latch piece but the latching area has been broken out. At some point someone must have made a patch and screwed it on, which accounts for the screw holes. The glove box probably got locked sometime and someone just pried it open, which will break that pot metal area.
The area should be solid as shown in the picture below.
I have repaired a few consoles that were broken similar to yours. I make a metal piece that goes on the backside of this area and JB Weld it in place. You can then fill the front side with more JB Weld or another type of good filler, sand and contour it, and finally paint it. It looks completely original from the top and has good strength. This is a glove box latch so it doesn't have to withstand extreme pressure, with the exception of someone forcing it as noted above.
Remember, this is pot metal so your repair options are limited. Also, don't pound on it for whatever reason or you could break it more.
Hope this helps.
Terry
Name:	Copy of 67 GTO CONSOLE TOP PLATE #2  #006.jpg
Old 11-20-2014, 11:27 PM
lazlo's Avatar
Thank you.... I will start on the appropriate repairs tomorrow.
[SIGPIC][/SIGPIC]
Old 11-22-2014, 06:51 PM
1966geeto 1966geeto is offline
I have the piece you need if it is the lower lid send a bigger pic I have a lid and the lower piece if interested.
Old 11-22-2014, 08:09 PM
lazlo's Avatar
Thanks, I finished the repairs & painted the semi gloss black on the console tonight. Looks good.
[SIGPIC][/SIGPIC]
Old 11-24-2014, 01:56 AM
lazlo's Avatar
repaired.. I was able to cut and bend a piece of steel to fit between the two points. Secured it with some Permatex cold weld. Filed to size. Looks like it will work. Lid fits nice & tight now.
[SIGPIC][/SIGPIC]
Old 11-24-2014, 02:25 PM
GT182's Avatar
GT182 GT182 is offline
Nice..... job well done Laz.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 11-24-2014, 08:28 PM
Nice work. I've got a similar issue with mine that needs to be addressed. I'll get to it later this winter when the interior comes out.
