Old 11-22-2014, 05:23 PM
David Brown's Avatar
David Brown David Brown is offline
Send a message via ICQ to David Brown
Default 1970 Bonneville Long Branch Issues
I installed my starter, then the long branch manifolds from Ram Air Restorations. So far, so good. But it looked like there was not enough clearance if I ever need to drop the starter, so I tried to remove it, and just as I figured it can't get past the manifolds.
Has anyone installed the Long Branch on a 70 (or 69) B body? Are you able to remove an original Delco Starter?
I do not have a problem now, but I don't want a repair nightmare somewhere down the road.
Old 11-22-2014, 10:28 PM
B Regan B Regan is offline
I had the same issue with my 66 Bonneville . It would only come out if I took the solenoid off. Your better off just buying a mini starter . Thats what I ended up doing .
Old 11-23-2014, 09:26 AM
jdh421's Avatar
jdh421 jdh421 is offline
mini starter is the way to go. much easier on the battery and wont heat up and quit. and it is easy to lift!
1966 Catalina Convert
1968 Firebird 350
1969 GTO
1967 Bonneville 4 Dr Brougham 428
1967 Bonneville 2 dr
1959 Buick LeSabre 2dr
Old 11-23-2014, 11:20 AM
I was wondering if a mini starter would solve the problem. Any recommendations for the right one for my 455, that has enough power to crank and fit in the tight spot?
I will still need to remove the one manifold to remove the starter. Easier now than down the road.
Old 11-23-2014, 11:59 AM
Doug Doug is offline
Get an I.M.I. Hi-Torque M-108. Fits well, ample cranking power. Good clearance. Good customer service.
http://www.hitorque.com/
Old 11-23-2014, 06:46 PM
importsmasher's Avatar
importsmasher importsmasher is offline
X2. I have had one of these in my 74 GTO for ten years or so. 455, long branch manifolds. No clearance problems, easy to R&R, cranks it over easily.
Importsmasher
Scott Baggiore
66 GTO convertible 389/4 speed (parents bought new)
73 Firebird Formula 400/4 speed
74 GTO 455/4 speed
74 Grand Am
Old 11-24-2014, 09:25 AM
Hitorque asks me for a Federal Tax ID Number to navigate on their site. I am an individual, not a business, so I don't have a tax number that I am aware of. I see lots of other vendors offer this type high torque mini starter. Any other comments?
Old 11-24-2014, 01:22 PM
I don't know if I.M.I. sells direct to customer. I bought mine from PY.
Call them at (888) 244-8675. Ask for Jack!
I've tried the I.M.I. Hi-Torque M-108 with both the factory longbranch and the aftermarket longbranch manifolds. Excellent fit, good clearance.
