1982-92 TA & FB TECH 1993-2002 TA & FB Tech is now part of the new Late Model Section of the PY Forums. Click this link to check it out.
Old 11-22-2014, 07:55 PM
PMDJIM's Avatar
PMDJIM PMDJIM is offline
Default the 305 gave up the ghost
The 305 in my formula crapped the bed. I suspect the oil pump was the guilty party. Am I crazy for buying a remanufactured 305 to keep it going.
1966 Catalina Station Wagon
1986 Fiero GT
1949 1st series Chrysler Traveler
1995 Formula Firehawk #592
Old 11-22-2014, 08:06 PM
Why not?
If the car is still in good shape and you were happy with the way the old 305 ran before it died then a rebuilt one will get you right back where you need to be.
Old 11-22-2014, 08:42 PM
PMDJIM's Avatar
Yeah. That's what I thought. I don't want to be bothered with changing computers or harnesses.
1986 Fiero GT
Old 11-24-2014, 12:54 AM
TTOP350 TTOP350 is offline
Is it a TBI or TPI?
either way, a 350 is a super easy swap.
http://www.fquick.com/garages/viewga...ewimg&id=74990
"You people have stood in my way long enough. I'm going to clown college."
-Homer Simpson
Old 11-24-2014, 10:45 AM
jmt455's Avatar
jmt455 jmt455 is offline
I think I would swap in a 350 and change the injectors.
Injector output is the primary difference between the 305 and 350 TPI systems.
FYI; when I helped a friend install a 1991 TPI in his hot rod I found these guys to be great help:
http://www.hotrodlane.cc/
They are very knowledgeable and helpful.
They can re-program the ECM for the 350 swap if you want to do it that way, as can Howell Engineering and TPI Parts.
"Keep your stick on the ice...and your head up."
1910 Buick Model 19 Touring
1924 Cadillac 5 passenger coupe
1933 Pontiac 4 door sedan project
1933 Sport Coupe project
1941 Packard 120 coupe - Factory AC and OD.
1968 GTO, 428, THM400, 2.73 posi cruiser
1958 Buick Caballero 4dr hdtp wagon
2018 Ram 1500 to tow stuff
2024 Buick Encore GX
Old 11-24-2014, 02:30 PM
PMDJIM's Avatar
It's TPI. Does the 305 intake swap to the 350?
1986 Fiero GT
Old 11-24-2014, 02:52 PM
jmt455's Avatar
Yep.
Great info here: http://www.hotrodlane.cc/PDFFILES/TPIStory.pdf
Old 12-03-2014, 02:02 AM
Yes it will You an use the 305 injs and buMp the fuel psi a bit You'll need a 350 knock sensor and ESC Module along with a 350 chip You can use the 305 heads to Sorry someone spilled a stiky drink on the keyboard and soe keys don't work now lol
-Homer Simpson
Old 12-03-2014, 01:06 PM
PMDJIM's Avatar
I didn't want to search all over for harnesses and computers. I just want to do a simple swap to get it on the road again. I guess finding a low mileage used motor will be impossible. So i may just go for a reman.
1986 Fiero GT
Old 12-29-2015, 09:16 AM
Nocar's Avatar
Nocar Nocar is offline
Default 5.7
Hey Jim, am parting out a 1991 B4C, has a MAF 1989 L98 in it, every piece, 5,7 exhaust manifolds etc is there, engine is extremely clean inside and I drove the car before parked, ran very nice. I am in TN but wanted to let u know. PM or call 615-542-2132.
1966 GTO
Isaiah 6:8
