Running or sitting on jack stands
So how are all the power adder Pontiac's doing?
Mine is running good, converter is still to loose, thinking my turbine side is too small for 488" may even check the psi by installing a gauge come spring. So what's up out there? |
Jack stands, engine stand, garage attic full of interior parts. Aligning all body panels fixin hinges etc drill alignment holes for realignment after disassembly.... then start my chassis building. Cost to do just back-half with cage kit is near same as doing 25.4 chassis in same material so might as well do 25.4 chassis instead. May never go that quick but better done now than redo later. I can go basic on motor til I'm ready to go more. So basically build a real strong shortblock and use stockish heads modest turbos. Only building a 406 as I plan for multiple purpose Street/Highway/Strip and drag week sounds like a future plan. Turbos can make up for a bunch of cubes and I can still get fair mpg at 406. twin 72's should more than cover my power needs when ready for better heads. MS-Pro with fuel sensing for gas or E85 is fuel plan regardless.
My Tempest is running, but with only one more race date this year (December 6th). They're running jet cars that day and I'm not sure about track prep. Still working on my tune-up. Made a couple of high seven-second passes last time out, but I think there's a tenth in the tune and another tenth at the starting line with a little more work. The schedule for 2015 isn't out yet, but I've got some off-season work to do: oil change, check compression, new front tires (purchased, but not installed yet). I hope to have it all sorted out by Pontiac Heaven in Phoenix in April.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
Blower Pontiac running good. Just upgraded to new front tires, installed some different springs to lower rear of car. Of course, had to buy new rear rims with more offset, so they fit in wheel well. Just waiting on new tires to show up, and will be ready once weather breaks... Hopefully get my 10:40 pass in 2015 in street trim....
Baby's suck on Bottles, Real men get blown. |
No jack stands. If you push it it moves. Engine in mock up and assy.
Up and running here, but winter weather has me out of action due to road salt.
I do have some winter upgrades planed in the trans department, new 6an lines with the addition of a cooler line relief valve and front pump converter feed restrictor. I went through thrust bearing hell on my turbo ford! it wont happen to my Pontiac. Im also thinking of having my 75mm compressor wheel upgraded to an 80, a local company can do it for $300. |
Running, but probably converting to jack stands for the winter.
Whitmore 462, 670 heads 10.55@125 Same with 310 E D-ports 10.12@131 498 w/single 88 8.53@158 |
Took out old 1 3/4 6 point bar and installing cage, so I wont have to slow down.
MR-1A Shortblock getting built 4" stroke 4.25 bore.....should be fun, aiming for 1000HP with the F1C.
1965 GTO hard top, Black with a red interior built to drive and Race best so far 1.45 60’ 8.77@164mph . 6 Speed manual transmission. MS3pro Fuel injection Multiport , 517cubes 10 to 1, 3.50 gears, CNC E-heads wideport 350CFM by Dave B. 4025lbs with driver!!94mm turbo. Winner of the Hot Rod Dragweek stick shoot out 2017! |
My Catalina is still by my good friends getting the cage finished up and a chute mount built. Hope to have it ready and driving by April Pontiac Heaven also.
Mark
My Gasser '63 Catalina build. Oh sorry, it's a Street freak. Either way it's a fun build. |
1990 Firebird (Was v6 base model w/aero pkg so it looks like TA) pics locked up in other pc til I get around to replacing power supply. Solid car I picked up minus v6 for $300. Cosmetically needs new nose piece and paint but its near rust free. Interior was a bit rough. Basically a great candidate seein Im goin Pontiac power narrowed Ford 9, big tires etc. Engine is my 59 block.
I'll start a build thread after I get around to fixin pc. |
Mine is running good in the driveway! Lol! Haven't driven it yet. Had to do a bunch of wiring....and I hate wiring. By the spring I need to change the gear, work on a cage, and see what the converter does.
It's collecting dust in the garage.. I took it out one month ago to let my neighbours know there's a maniac living close by LOL...
*** THE BIG BRACE is here *** |
My car is sitting on the car hoist in the air, ready to ROCK & ROLL next year!
GTO George |
Mine is in the neither category. LOL
East Coast Mafia TTFMF Making CVWHAT's great again. I guess it took a deplorable ECM member to do it! Quote:
Fastest Blow-thru Pontiac powered car in the Country 8.440@166.97 (3465lbs) Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: 4.80@147.65/ 7.49@180.12MPH (3365lbs) |
Sitting on a hoist, no wonder it's ready to go. |
Looks like it will be a beast!!
