Old 12-04-2014, 08:24 AM
Danla Danla is offline
Default Anybody have a 68 air car?
I need help with the vacuum hose configuration on the control panel. The connector is gone and all i have is a bunch (6) vacuum hoses hanging. 68 was a year by itself so i can't find a good diagram to locate which color hose goes on which port. I have the engine vacuum hose figured, but any combination i use with the others doesn't seem to work. Last time i tried. the heater doors open and close, but when i put the temp on hot, it blows cold air and vice versa. Any help or ideas?
Old 12-04-2014, 01:40 PM
fyrebird68's Avatar
fyrebird68 fyrebird68 is offline
Deleted - wrong info!
68 GTO ragtop
91 T/A
69 XKE
Old 12-06-2014, 09:51 AM
ponchjoe's Avatar
ponchjoe ponchjoe is offline
I have mine apart. I will try to get out to the shop this weekend and see if they are color coded to help you out.
Joe
Old 12-08-2014, 01:13 PM
AC schematic in shop manual covers all that. While 68 is a unique looking control head the function of the AC system is the same (except for the compressor cut-off in 69+) as relates to door control.
Drawing lists hoses by stripe color.
