Old 12-05-2014, 11:00 AM
67cruiser 67cruiser is offline
Default Radiator chat & Value??? 4 core!!
Well maybe thinking about a aluminum radiador for my 67 GTO.My currant radiator is a 4 core,coper, approx. age is 4 yrs old.Desert core name i believe. Works great but in the staging lanes it does climb to 205.Car is 80% drag car. Still running a water pump.I know aluminum dissipates heat better. Running water with water wet installed.Whats your thoughts on this subject???Worth the effort or stay with what i have???I have factory shroud & fan installed.
What would be the value on a radiator like mine??? Think i paid like 300.00$ for it/
Old 12-05-2014, 11:16 AM
78w72 78w72 is offline
you'll get a lot of opinions on this subject, heres mine.
your 4 core "should" be cooling the engine just fine based on your specs i remember reading. check all other aspects like water pump, pump clearance, fan location in shroud, fan clutch, t-stat, etc etc. especially if you are running straight water with additive, sounds like something else is contributing/causing the temp issues...
but yes, an aluminum radiator will cool better than the factory copper rads. anything from super expensive big row 2 cores, or if you are on a budget the 3 & 4 core champion brandss are a great value & actually very good quality & lifetime warranty. yes they are made in china & some frown on that, but again, if you are on a budget & want better cooling they work great.
have read about many guys with 500+hp engines that use them & love them. i have the 3 core champion in my 500+hp mid 11sec firebird & it does not move above the t-stat rating no matter what condition the car is in, 90+ degree humid days in staging lanes, stop & go traffic, prolonged highway speeds etc etc.
cant comment on a gto or other make version, but on a 2nd gen bird the fit was perfect.
Old 12-05-2014, 02:18 PM
Great answer, Thank You, Im not running any restictors or a stat in the motor, may look into this.
Old 12-05-2014, 04:13 PM
Rob B's Avatar
Rob B Rob B is offline
There's your problem right there.
74 GTO Bracket/Street car and another 74 for the wifey to race with!
70 GTO 400, 4 spd, #'s matching and a little to nice for me to own.
Friendship is like peeing your pants..everyone can see it but only you can feel the warmth!
Old 12-05-2014, 04:47 PM
Flyin79bird's Avatar
Flyin79bird Flyin79bird is offline
Try a T-stat. I drive my car to the lanes...down the track and back to the pits and it never gets above 170. This is with 15:1 compression, straight water and a gutted T-stat just to give it enough restriction. BTW...I have a 3 core copper radiator. Nothing fancy.
68 Firebird "Indian Giver" 540 MR1, HP's, Wenzler -- For Sale $12,500 rolling Best of 5.12@134 on 175 shot
72 LeMans "POS" - Next US beast
Old 12-05-2014, 05:48 PM
goatless's Avatar
goatless goatless is offline
You mean he should fine tune what he has (by installing a $6 thermostat) instead of continually throwing high dollar parts at it and never getting spending the time to get them to work right????!
Novel concept.
1966 GTO
Old 12-06-2014, 01:24 AM
Original Hei for yrs. original intake for yrs. original top end for yrs. throwing money into combo makes no sense.Like driving a green car, makes no sense.
Old 12-06-2014, 01:36 AM
t money t money is offline
Some times I have no idea what you are taking about Rich.
Old 12-06-2014, 07:39 AM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
I agree with the tstat. Or at least a restrictor. I cut the center out of a t stat and run mine that way. Works great.
Old 12-06-2014, 08:51 AM
goatless's Avatar
Really Rich?
The green car has an original style parts store radiator (and never goes over 170 degrees in the staging lanes!), has an untouched original factory intake, an original Q-jet, factory iron heads, factory iron LOG exhaust manifolds, factory fuel lines, factory un-modified fuel tank, all of it's factory steel bumpers and body panels.
Your white car has aluminum intake, aluminum heads, headers, sumped fuel tank, fiberglass bumpers and hood. It weighs a good 400-500 pounds less than the green car and still it runs 2-3 tenths slower. That is what makes no sense!
1966 GTO
Old 12-06-2014, 09:58 AM
mysticmissle's Avatar
mysticmissle mysticmissle is online now
You've bn served!
Old 12-06-2014, 10:32 AM
Tom Vaught's Avatar
Boost Engineer
Novel concept.
X2. You can save a great deal of money and get a very strong running car by taking the times to research the known fixes out there for most of this stuff.
Water pump blade to divider plate mod has been out there for years.
Gutted Thermostat is well known.
On cars with working thermostats, drilling a couple of bleed holes in the stat to get rid of air pockets at the cross-over when the stat is closed is known..........................
So do some HOMEWORK FIRST then if you still can't figure it out bring it to the board.
Tom V.
Old 12-06-2014, 10:39 AM
Tom, with all do respect, been there done all that. Thank You
Old 12-06-2014, 10:47 AM
Tom Vaught's Avatar
Boost Engineer
Did you check the timing to make sure you had enough Advance?
Did you check the carb to make sure the carb calibration was not too lean at idle.
Both can cause cooling issues (with the best radiator).
Tom V.
Old 12-06-2014, 12:27 PM
60man's Avatar
60man 60man is offline
Ditto Rich....be sure there in no air trapped in cooling system..
If fan has a thermal clutch on it have you tried another fan??
They do go bad..
ECM member.
MANDRA
Old 12-06-2014, 03:24 PM
Gary H's Avatar
Gary H Gary H is offline
Default Pulleys
Do you have non A/C pulleys or A/C ones? The pulleys on a A/C car for the water pump and balancer are sized (diameter) differently than the non A/C ones. Check to see what you have. I've seen 10-15 degree drops in temperature just by changing pulleys to get the water pump turning faster.
Old 12-06-2014, 05:09 PM
GTO Dan's Avatar
GTO Dan GTO Dan is offline
Just buy Langer's car and drivetrain and be done with it.
Old 12-06-2014, 08:35 PM
Timing all checked out, perfect for me.
Super Duty repo pulleys
Running fully degreed balancer
Carb. runs like a bare extremely strong.
My clutch fan is new
Timing set 38 degree,s at 2800
My next thing i am looking at is loosing the front factory springs going to Moroso
You name it i probably checked it.
Springs is something i reaaly should of checked first, lol won,t help cooling!!! AkA
I believe someone not telling how much he has in his intake from SD Performance& heads!!
Old 12-06-2014, 08:43 PM
goatless's Avatar
Alright, Rich... even though you'll ignore me, I'll try to help you yet again.
A 4 core desert cooler should have no problem cooling a mild 400. Changing to an aluminum radiator is not going to make much of a difference. If you are not running a thermostat or restrictor then the water is just cycling through your radiator too fast for it to transfer the heat out of it.
1966 GTO
Old 12-06-2014, 08:50 PM
WOW Rich y do you post here. Your car is perfectly tuned. When you tell Tom V I have done all my research I have to ask were did you find the information about running no t stat or restricter in your cooling system.
