Any 1970, 71, 72 Trans Ams built with Hood Tachometers?
Throwing this question out there to others who have more knowledge and experience than I do on 1970, 71, 72 Trans Ams. Were the UPC "U85 Tachometer, Hood Mounted" aka: Hood Tachs ever available as an option on Trans Ams?
Don't see it on this 1972 Firebird order form http://www.gt-37.org/gallery/main.php?g2_itemId=5184 |
Never say never - right? Post them if you have any documented 2nd Gen 1970, 71, 72 TRANS AM built with a hood tach please!
Never seen one or heard of one ever being built.
1970 Trans Am 1971 Trans Am 1974 Trans Am 1978 Y88 Trans Am W72/auto 1979 10th Anniversary Trans Am 1984 Trans Am 1993 Trans Am 1999 30th Anniversary Trans Am 2001 10th anniversary Firehawk #104 2006 GTO |
Thxs. "Well someone on the Internet said...'Bonjour!'"
I think that one ^^^ was built late in the day on a Friday.
Alvin, I don't know where my old book is but I remember that in my little sales book the one that use to go in my pocket, it's about 4 inchs wide by 10 inchs tall. But in there I think is where I remember seeing it last. But in my order book when you got into the gauges there was an astrist & when you went down to the bottom of the book you saw the note saying that when useing the hood tach that the in dash tach was replaced with the large clock & there would be an additional charge of ?? At least thats where I think I saw it last. I'm not 100% sure but I do remember the astrist then the note to go with. It was similar to when you got a hood tach on the A-bodies there to was a note about the speedo with the trip odometer. But thats a different subject. As I mentioned before the only hood tachs I've ever seen on an F-body has been a Formula, & now that T/A in the pic post.
I'm going to say no to the factory installed hood tach.
No mention of it in the factory assembly manual. The hoods lower brace structure has no cut outs or features to provide clearance for the fasteners and wiring.
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int 1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int 1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int |
I have the 1970 order forms, 1970 price sheets, and 1970 Pocket Facts.
Hood tach was not available on the 1970 Firebirds, or the 1969 Trans Am's.
1959-1980 Pontiac Window Sticker Reproductions : http://www.pontiacwindowstickers.com My Bio: I am currently writing articles for POCI's Smoke Signals magazine and enjoy promoting and discussing the history of the Pontiac Motor Division. |
The Following User Says Thank You to MikeNoun For This Useful Post: | ||
Thxs for the input. Seeking any verifiable Trans Am factory hood tach info like the attached "1970 Tempest Hood Tach Installation" page courtesy www.gt-37.org for 1970, 71, 72, 73 Trans Am.
I have to disagree with you when you say that no firebids came with a hood tach. As I had mentioned earlier in this post I have seen 3 formula's with hood tachs on them. The one that is here in town is owned by the original owner & he has the build sheet for his with the hood tach listed on it. Wheather there is a place in the bracing for it to come through the hood for mounting or not the hood tack was availabe on the formulas , if not the Trans Am's .
if so pix? Documentation too would be so cool.
I know a couple of 72 455 HO verts that the original owners swear were GTOs because they ordered them that way, only to find out the dealer did the magic...
Mike/Illinois |
OP title: Any 1970, 71, 72 Trans Ams built with Hood Tachometers?
Bonjour & Merry Christmas! |
Rex, yes - pls post that build sheet. If it shows a hood mounted tachometer on it the history books will need a small re-write.
keith k 70 Trans Am RA III / T400 / Lucerne Blue / Bright Blue 70 Trans Am RA III / M20 / Lucerne Blue / Sandalwood 70 Formula RA III / M21 / Lucerne Blue / Bright Blue |
1970 FORMULA
from the cover of HOT ROD...most likely an early GM car...I think a hood tach looks good on a Formula hood..a T/A not so much..perfect for a Formula with out the gauge option...I am not buying 2 tachs on a car..overkill
The Following User Says Thank You to transam1972 For This Useful Post: | ||
While flipping through some 1972 Firebird literature I had in an attempt to help answer Brewster's question on what came with the Custom Trim option, I found this little gem on hood tachometers. Far from conclusive as others have pointed out that the sales literature was not gospel, but interesting nonetheless.
Yes the yellow 70 pilot Formula was built with a hood tach, but thankfully the RPO was cancelled in regular production. I've seen no order forms, invoices, build sheets or window stickers indicating an early 70s Firebird came off the end of the line with a hood tach. Unlike a RAIV Formula I have seen no evidence that it was even theoretically available. |
FORMULA HOOD ON A TRANS AM
..forget the Formula hood and a shaker.(CHiPs) anyone?!).but when you look at that T/A and forget about the shaker & tach...if the TRANS AM had only come with the fiberglass Ram Air twin scoop hood and the stripes on top of the scoops to match the roof & deck lid like originally planned a shakerless T/A looks pretty darn cool..imagine if it had been the other way round (like the S.D. 455 FORMULA)..I think the TRANS AM would have looked sleeker and way cool (plus I would have that dual scooped hood!!)
