Old 12-26-2014, 11:00 PM
melemans's Avatar
melemans melemans is offline
Default 64 GTO lower 2-groove crank pulley
Does anybody know if lower double groove pulley #9786713 (7 3/8" D. x 2 1/4" H.) is correct for a 1964-1966 389 engine? It has 3/8" and 1/2" grooves. The only info that I can dig up is that it fits 1967-70 GTO, Lemans, FBird, Catalina.
Old 12-27-2014, 12:41 AM
1lms 1lms is offline
None of the 64 pulleys had #s on them. I will check what I have tomorrow for you. I know the 65 pulley is the same but has a part #.
Old 12-27-2014, 10:02 PM
melemans's Avatar
Default 64 crankshaft pulley
Thanks for the reply. Please let me know if you find out anything else.
Old 12-27-2014, 11:15 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
I found 64 and 65 use the same 2-groove crank pulley.
#9775627 (7-9/32'' dia.)
Old 12-28-2014, 04:21 PM
Sorry I only have the 65 pulley with the part # on it. It is the same as the 64 but not correct for concourse judging.
Old 12-28-2014, 05:15 PM
8LUG 8LUG is offline
2 groove pulley for 65 shows 7-1/4 9778802 just 1/32 smaller than 64 from MPC 12-1-64
Old 12-29-2014, 09:30 PM
64woodwheel's Avatar
64woodwheel 64woodwheel is offline
Actually the crank pulleys on 64s and 65s are not 100% interchangeable. On 65s the grooves are farther away from the front of the engine. On cars without power steering they use the same water pump pulley. In '64 the belt rides in the front groove of the crank pulley and in '65 it rides in the rear groove.
