Just a few quick pics to see how lobes look after 4400 miles.
Lifters have less than a thousand miles due to originals collapsing. Melling SPC-7 and Johnson lifters that are quiet at 1/2 turn preload. Had to remove intake to repaint and reseal, so I wanted to inspect while opportunity presented. Does the lobe wear pattern on nose of lobe appear normal. Ran a day ago to see if all pushrods were spinning ,and a few were slower than rest at idle but then would speed up some at higher rpm. The lifter pic is of one of the ones that were slower and still has raised center and good swirl. If I try to spin pushrods when they are on base of lobe the lifter spins on some and just the plunger inside the lifter on others. Always used either Brad Penn or rotella with ZDDP and filter was clean. Thanks for your thoughts Gerry
1968 Firebird 400, 068 cam, TH400 & 13" Continental Converter, Auburn posi with 3:08 factory gears, Cliff's Q-jet resting on a 68 factory iron intake, GM HEI and Ram Air pans and RARE Long Branch Manifolds |
Are you sure the cam was not damaged when the lifters were changed, The one photo of the cam seems like the lobe is wearing bad.
When you adjusted them, did you make sure the the plunger was not down a little then you went another 1/2 turn? I go 1/4 turn after 0 lash, but you have to watch the lifter close to make sure the plunger is not going down bwfore you tighten it.
Watched real close to see when plunger just cam off clip and then 1/2 turn.
This is with 7/16 studs with crimps nuts, fine thread. The original lifters had a few that ticked a hair to much and one was spongy. The new lifters have been very quiet after a few seconds once started. just was looking to see if wear was normal, considering I swapped lifters Last year. I thought if wear mark went clear across nose of cam, lobe was considered worn. Gerry
If there's any question, cut open a filter and look for magnetic glitter. BTDT
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports, 3" pypes, Hooker 1 3/4" headers, hydraulic roller, 10" Continental, 3.42 gears 11.5 @117.5mph 3900lbs ![]() ([_|_] ##\|/##[_|_]) |
The bottom of the lifter starts out as a perfect dome, and will start to flatten in the center when things go bad. Putting two bottoms together and holding them up to a light source and rocking them sometimes is the best way to see if the centers are starting to flatten.
Mick Batson 1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 Catalina Safari Wagon. |
That thing is gone. I see multiple lobes that are not only worn all the way across but also a slight arch to them.
I blew up the cam3 pic and was able to see better. In general, if the lobe is worn across the entire tip/nose of the lobe, it's worn out. There appears to be discoloration from overheating too, suggesting the lifters weren't turning at some point. Maybe post some better pics just to be sure. .
Close up of pic 2...
What was done to break in cam???
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down...
this cam was installed 5 years ago and breakin was with
rotella and gm eos for 20 min and yes they all pushrods spun at that time. during that time I did have a temp issue which has been resolved. also numerous oil changed through the years and accumulated close to 5000 miles. I will admit I learned ALOT and last year swapped out lifters due to some being spongy. new lifters were installed with paste and run in as a normal breakin. just curiosity caused me to pull valve covers and inspect. will pull all lifters soon and cam. already have a new melling spc-07 on hand and crower cam saver lifters on order.
You caught it early, before it started really eating up lobes. Clean up should be minimal, should consider yourself lucky! And you get some more garage time too, which is all part of it. I go into the garage sometimes and just stare, it's a mental health thing for me!
Amen and amen. I thought I was the only one.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core.
