Old 01-04-2015, 07:53 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Default Global arms and 5662 springs
Here is a picture of the 81 TA with the new Global upper and lowers and the old MOOG 5662 springs I had in the 79 Camaro. 2.5" tire to fender lip 255-60-15. 15 3/16" fender lip to center of wheel. Springs had been in the Camaro for years then out for 3 so may settle a little but don't expect much.
"Stringing" it to get the toe close-hard to do with those rear wheel opening spoilers.
Skip Fix
Old 01-14-2015, 08:14 PM
SMW SMW is offline
How does it ride with those springs. The easiest way to set toe is with toe plates. You can get the plates with 2 measuring tapes for about $56.
Old 11-17-2022, 12:42 PM
MO Olds MO Olds is offline
Can you use the 5662 with stock upper and lower control arms? The stance looks great. I know this is an old post but have same question above, how does it ride? Do you recommend this spring as a stock type replacement?
Old 11-19-2022, 10:04 AM
Skip Fix's Avatar
Yes I had them in the Camaro when I autocrossed it. Same pair of springs I used then.
Bought toe plates -lots easier than the double garage bags. and a longacres caster camber gauge.
Skip Fix
Old 11-19-2022, 12:17 PM
Awesome - thanks! But to confirm, sounds like the 5662 is more stout than stock (autocross) and not a good stock-type replacement?
Old 11-23-2022, 10:48 AM
Skip Fix's Avatar
yes it is stiffer than the stock 330lb/in spring. Autocrossing and stopping in a turn you get front end dive and that un loads the rear causing some loss of traction. For my driving a stiffer front spring helps better for that as just a bigger sway bar will still dive.
Skip Fix
