Old 01-09-2015, 06:25 PM
charles bledsoe's Avatar
charles bledsoe charles bledsoe is offline
Default 72 rear bumper brackets/bolts
I'm trying to install the rear bumper on the 72 Formula. When I purchased the car the bumper was wraped in paper as it had been sent out to be re-chromed. Inside the trunk there was a box full of various parts. I believe the brackets are in there, but not sure what I'm looking for. Does anyone happen to have pictures of the brackets and bolts you can post for a 72? Also could anyone who has the 70 assembly manual scan and post the page which shows how it is bolted on? I did a search, but only saw info for a 73 and I understand there is a slight difference due to new bumper regulations that were mandated in 1973.
Thanks in advance.
Chuck
1966 GTO Vert automatic.
1969 CR Judge Ram Air III 4sp Pattern Car.
1969 GTO standard 350HP TH-400.
2006 GTO Phantom Black 6spd.
1972 Formula 455HO Ram Air.
1976 LE Trans Am 50th Anniversary Edition with T top.
1976 Formula 350.
1977 Grand Prix Model J 350.
1978 Trans am 400 Pontiac.
1979 Trans am 403 Olds.
1968 Olds 442.
1971 TR6.
Old 01-11-2015, 11:05 AM
Brewster's Avatar
Brewster Brewster is offline
Default Bumper
Hey Charles, here is a picture from my 72 Service Manual. Let me know if this answers your questions?
Cheers, Brew
Old 01-11-2015, 01:03 PM
Burgess's Avatar
Burgess Burgess is offline
Default 72-73 bumper brackets & bolts
I dug out a set of 72 brackets, (top), and a set of 73 brackets, (bottom).
They are placed in the positions that they are mounted on the car.
The difference of about 1/2'' in length is apparent, and on the end brackets the hole spacing is offset more to move the 73 bumper further away from the body.
Pictured also are the bolts, from the 72 set, need 10 of each. The stainless capped 3/8'' thread bumper bolts have a 3/4'' diameter head, 3/4'' long under the head, and the nut has a 1'' washer attached. The 3/8'' thread body bolts have a 1 1/8'' washer and are 1'' long under the washer.
The last picture shows a rubber strip that goes on the sheet metal support that is welded to the rear body panel under the filler neck hole. I'm not sure if all years have this, or just 73's, to take up the extra space between the bumper and the body piece. I've only come across one on the cars I've had, a 73.
Name:	70-73 bumper brackets 017.JPG
ID:	387117   Click image for larger version
Name:	70-73 bumper brackets 011.JPG
ID:	387118   Click image for larger version
Name:	70-73 bumper brackets 019.JPG
Old 01-11-2015, 01:16 PM
Burgess's Avatar
Default some closer pics
Here's some closer pics of the 72 set, with comparison to the 73 end brackets.
Name:	70-73 bumper brackets 002.JPG
ID:	387120   Click image for larger version
Name:	70-73 bumper brackets 003.JPG
ID:	387121   Click image for larger version
Name:	70-73 bumper brackets 008.JPG
ID:	387122   Click image for larger version
Name:	70-73 bumper brackets 009.JPG
Old 01-13-2015, 01:25 AM
Brewster/Burgess- thanks for the service manual diagram and the pics. I believe I have the brackets and some of the bolts needed to install the bumper. From the diagram it looks as if the brackets bolt up to the rear facia panel. On the inside of the trunk (on my car) it looks like there are brackets affixed which the bolts most likely go thru to attach the out side brackets you sent pictures of. Is this correct? I'm guessing the stainless capped bolts are the ones that are used to attach the bumper to the outside brackets. Do either of you happen to know if the stainless bumper bolts are reproduced? Thanks again for all the help!!
1976 Formula 350.
1968 Olds 442.
1971 TR6.
Old 01-15-2015, 08:21 AM
FunctionalShaker FunctionalShaker is offline
Earlier cars had that rubber strip as well, but with a different configuration. I believe AMK might have the stainless capped bolts.
Old 01-15-2015, 10:56 AM
Bentwheelbob's Avatar
The stainless capped bolts are available from a variety of suppliers. You want to make sure you get ones with "low profile" heads as opposed to standard carriage bolts that have a more pronounced head. Here's a link for some for sale on Ebay.
http://www.ebay.com/itm/GM-Camaro-Fi...318ef6&vxp=mtr
Here's another link that has the flanged nuts with serrations.
http://www.ebay.com/itm/GM-Bumper-Bo...783dc2&vxp=mtr
Old 01-16-2015, 04:10 AM
Formulabruce's Avatar
Look at this pic, there are square stick on "paint protectors" used by the factory to keep from scratching car during install. Easily made and worth sticking on your car... My 2 cents..
" Long may we DRIVE !"
Old 01-16-2015, 07:17 PM
Burgess's Avatar
'' Look at this pic, there are square stick on "paint protectors" used by the factory to keep from scratching car during install. Easily made and worth sticking on your car... My 2 cents..''
Could those be body putty 'squares' stuck on to seal up the holes? There's usually sealer between there when removing originals.
Old 01-16-2015, 10:14 PM
They are thin foam, one side sticky, squares from the factory. I suppose they do/could seal the holes as well. I found them very much a good idea, especially on the sides.
