I need three of the right angle brackets that stabilize the bottom of the front grills on my '68 Firebird. I have one of the four pieces, but can't find the others. They are small steel 90 degree brackets about 2" X 2" with a single hole in each wing of the bracket.
If needed, I'll post a picture of the bracket.
FWIW, Those are being repopped now if you can't find originals.
I need only three of the four brackets. Here's what they look like--about 4" from end to end.
I'll take anywhere from one to four pieces if you have them.
I might have some spares? I'll have to get back to you. Scott
Thanks, Scott. Let me know.
HI Dick. I found those 3 brackets your looking for. I had to make sure I had at least 4 for my Firebird. There blasted , primed and ready for paint. PM me if your still interested. Scott
Do you have any extra's? I just need one.
Thank you! |
those should have a rubber bushing in the hole so the peg fits tight
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
That is correct!
I have a set of 4 brackets without the rubber bushings for 40.00 plus shipping. They should fir in a small USPS box for 10.20 so total would be 50.20. I use paypal. 763-913-9573
Thank you Kent, I was trying to avoid buying a complete set since I only need one.
Then split them with the original request from Dick Boneske.
