Old 01-16-2015, 08:25 PM
Hillard's Avatar
Hillard Hillard is offline
Default Anyone know their bobweights??
I just calculated mine and curious how it compares. Please state what rod/piston combo along with rod length and bore size. I think mine is very light and can't wait to get it together and see how it revs.
Old 01-16-2015, 11:07 PM
mike leech's Avatar
mike leech mike leech is offline
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
Old 01-16-2015, 11:42 PM
Hillard's Avatar
I've got BME 6.8 rods/ 4.211 Ross pistons = 1875.9 grams
Old 01-17-2015, 12:07 AM
mike leech's Avatar
That's light
EHTTFMF!
Old 01-17-2015, 12:14 AM
65nss4spdGTO's Avatar
65nss4spdGTO 65nss4spdGTO is offline
Most of the 6.800" steel rod, shelf style pistons with big rings are around 2150g.
My little 400ci came in right at 1700g.
The 7.100" Carrillo rods weighed only 614g, had a short skirt flat top piston and .043" rings.
1875g is pretty light, what rod journal?
Calvin Hill
Hill Performance
708-250-7420
Old 01-17-2015, 12:23 AM
lust4speed's Avatar
Scat 6.80 rods, RaceTec 4.31 pistons, bob weight 2185
Eagle 6.80 rods, RaceTec 4.185 pistons, bob weight 2149
Eagle 6.80 rods, Ross 4.180 pistons, bob weight 2110
RPM 6.80 rods, SRP 4.180 pistons, bob weight 2036.4
Mick Batson
Old 01-17-2015, 06:15 AM
Hillard's Avatar
2.20
Old 01-17-2015, 06:16 AM
Hillard's Avatar
Calvin Hill
Hill Performance
708-250-7420
I can't believe those steel rods are that light...wow.
Old 01-17-2015, 09:53 AM
mgarblik mgarblik is offline
Nitro Pontiac= 2420 grams 4.250 bore. BME 426 forgings, 1.094 pins, Big, thick BME pistons. Strength over weight. 8500 RPM. .Rods 6.7" Piston weight 630 Grams We overbalance 1%
Old 01-17-2015, 01:37 PM
Hillard's Avatar
When forcing nitro in, you definitely consider strength over weight. Your pistons are almost 200 grams heavier than mine, but mine wouldn't last for a burnout in your application.
Old 01-17-2015, 06:47 PM
Yea, you do need the extra weight in some power adder applications. When we were first working the tune-up a couple years ago we bent one of those 1.094 VascoJet wrist pins. I couldn't believe it!. It was bent .003" The flat top pistons are almost .400 thick. As far as pistons for NA and high RPM Pontiacs, Because of the short cylinders, I would try to keep as much structure and support in the skirt area as possible. Certainly around the pin boss and the underside of the piston, they can be light.
Old 01-17-2015, 08:41 PM
Bob-o Bob-o is offline
eagle 6.8 rods, probe 4.155 pistons, 2160 Bob weight
Old 01-18-2015, 02:28 PM
john marcella john marcella is offline
Calvin Hill
Hill Performance
708-250-7420
Do you mean 6.100 rod ?
John Marcella
Marcella Manifolds Inc.
[email protected]
ph. 248-259-6696
Old 01-18-2015, 02:47 PM
mike leech's Avatar
Those are dinky.
EHTTFMF!
Old 01-18-2015, 02:49 PM
mike leech's Avatar
Not being a smart azz but you did double real big end and the rod bearing weight as well?
EHTTFMF!
Old 01-18-2015, 03:44 PM
Half-Inch Stud's Avatar
need 1 BME 426 6.625 with 927/2.200 ends to complete a spare Street motor.
Old 01-18-2015, 04:33 PM
BLANK1's Avatar
BLANK1 BLANK1 is offline
In my 461 stroker, 4.155 ROSS pistons and 6.8 RPM Ultra Lite A beam rods came in at 1957g.
Old 01-18-2015, 04:48 PM
Hillard's Avatar
Yep. Don't have the numbers in front of me but the rods weighed 660 total (about 450 big end/210 small end), bearing about 50-ish, 444 for pistons, 145-ish on the pins, 7.5 support rails, 57 rings, 4.8 locks, added 5 for oil. Again, those numbers are off the top of my head but I know I'm really close on the numbers for the rods and pistons.
Old 01-18-2015, 05:58 PM
rompn63's Avatar
rompn63 rompn63 is offline
Bob weight 1972.7 gms
Old 01-18-2015, 06:05 PM
No, these were used in my stock block 400ci.
SBC rod journal, .866" piston pin.
Calvin Hill
Hill Performance
708-250-7420
