Old 01-19-2015, 05:45 PM
540goat 540goat is offline
Default Vent window reassembly.
I am redoing the vent window assemblies on my 67, have some trouble getting them back together.
Any tips or diagrams or how to's on this subject.
Old 01-19-2015, 06:37 PM
Jeff Hamlin's Avatar
Getting the frame into door, or the frame assembly itself?
Old 01-19-2015, 08:10 PM
Frame assembly itself. I took the whole thing apart and want to make sure it's going back right.
Old 01-20-2015, 06:43 AM
It's somewhat straightforward but I recall them being riveted together so will require a new rivet or screw in the lower frame rail.
Here are some sites/info; that may be of help.
1967 Fisher Body Manual.
A-Body Vent window info; starts on Pg 6-45
http://www.thefirstgensite.com/libra...67S6P22_86.pdf
This is a decent write up at Hagerty.
More about the glass replacement but may offer some help.
http://www.hagerty.com/articles-vide...ss-Replacement.
I don't have any loose vent window frame assemblies on hand but may be able to offer any assist with ones on the cars.
Old 01-20-2015, 07:36 AM
They are bolted together. The GM one just shows how to get the assembly into the car and the Haggarty has partial information. Thanks on posting those. I am having some trouble in getting the vent window and frame to sit in the center of the frame. It sit a little crooked in it. The top is too close to the chrome frame.
Old 01-21-2015, 08:18 AM
chrisp chrisp is offline
Once bolted together all should line up , unless the top vent glass frame pin is bent .
Old 01-21-2015, 01:46 PM
Somehow the pin got bent and I had to tap it until everything fit right. Thanks guys.
Old 01-22-2015, 01:46 PM
Peter Serio's Avatar
Peter Serio Peter Serio is offline
I found a place that sells all of the vent wing special rivets and the tool to press them into the finished shape. Check out www.fillingstation.com
Their prices are very reasonable.
Peter Serio
Owner, Precision Pontiac
