Old 01-20-2015, 12:51 PM
Classicsworkshop's Avatar
Classicsworkshop Classicsworkshop is offline
Default 66 GTO with A/C, Fan Clutch
What is the most correct fan clutch for a 66 GTO, Tri-Power with air?
Eaton w/ coiled spring? or Schwitzer with the flat spring?
Also were the fans attached the clutch with bolts (I believe this is correct) or studs like some other GM products from similar vintage?
Thanks!
JD
