Old 01-21-2015, 12:45 AM
oethel's Avatar
oethel oethel is offline
Default collector extention length
Made some extentions extra long and want suggestions on optimal length.have seen guys put paint and grease on them.they would do a run and cut where the paint or grease quit burning off.also saw some one wait for a blue ring to develop and cut on the back side of it for best results.
Old 01-21-2015, 07:29 AM
steve25 steve25 is online now
If you are not seeking every last spec of HP from your motor than the burn the cheap paint off deal will work fine!
Since you did not state what CID motor you are talking about, nor its max rpm then in general 14 to 18 inches will do it and if the motor never really see's over for 6k RPM for more than 3 seconds on a run then a 18 inch lenght will sever you the best!
Old 01-21-2015, 01:26 PM
SLICK1 SLICK1 is offline
Arrow
Anything between 12 to 18 inches will get you in the ballpark, the merge style and flowmaster collectors are a bit better tho!
(see it in action)
http://video.tinypic.com/player.php?v=2sbpmkm
Old 01-21-2015, 02:12 PM
firechickenman's Avatar
firechickenman firechickenman is offline
I put 3 1/2" dia. 24" long extensions on my 3 1/2" collectors. Never cut them down to the length where the paint quits burning (looks to be 16"-18"). Am I giving up a little HP there? I like the way it quiets down the exhaust inside the car. Sounds better outside too!
Greg Weigart
IAIIA 520/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radial Pro/3300lbs/1.35 60'/[email protected]/[email protected]
Hot Rod Drag Week finishing averages:
2014 - 11.12 @ 118.56
2015 - 10.84 @ 124.97
2016 - 10.56 @ 127.88
2017 - 10.29 @ 130.74
2018 - 10.29 @ 130.53
2019 - 10.16 @ 132.34
2021 - 10.09 @ 132.69 - Quickest Pontiac
2022 - 10.13 @ 133.07
2025 - [email protected] - 2nd place SRBBNA
