Old 01-22-2015, 09:25 PM
pontiac6269's Avatar
pontiac6269 pontiac6269 is offline
Default Tubing size for frame bracing
What size and kind of tubing do you use for bracing the frame? I have a 78 Cutlass Supreme that I'm going to use for drag racing. I want to brace the frame at the upper and lower control arm mounts, connect the rear shock area and some other areas that may need it. I had a 6 point roll bar installed last fall.
Thanks,
Eric
Eric
1969 GTO - 461, turbo 400, Continental 13", 3.08 gears. - 12.59 e.t. @ 108.43 mph, 1.898 60'
1978 Oldsmobile Cutlass Supreme- 461, turbo 350, PTC 3500 converter, 9" 3:50 gears. = 11.39 e.t. @ 117.55 mph, 1.599 60' on E85
Old 01-26-2015, 09:37 PM
blueghoast's Avatar
I used gussets in the corners for a customers car
In the corners of the top spring pockets and in front of the
rear cross member and some other inside corners To.
Can't remember them all It's been a long time ago.
It was a G-Body Malibu.
GT.
