Has anyone run this cam?
Lunati Voodoo cam Advertised Duration (Int/Exh): 282/290 Duration @ .050 (Int/Exh): 231/239 Gross Valve Lift (Int/Exh): .530/.550 LSA/ICL: 110/116 Valve Lash (Int/Exh): Hyd/Hyd RPM Range: 2200-6200 Looking to run in 462 10:1 motor Edelbrock heads (87cc) 4:10 gear 28" tire I want a driver, comparable to a c6 corvette power. 68 Firbird
If its one thing I know, its..... Uhhh I forgot .What do you mean I couldnt be the president of the United States of America, Its still WE THE PEOPLE, RIGHT!! ![]()
I purchased that cam, but haven't finished installing it in my 455 -- hopefully in the next few days.
The ICL should read 106°. Typo on the catalog, but timing card shows 106°. |
Definitely install it at 106°. The VooDoo cams HAVE to be at least 4° advanced to work right.
What's the specs on the motor Nacho?
Lugnutt,
455 + .040". 9:1 compression, port matched iron d-port heads. |
You have way too much gearing.Do you have the heads already?How much power do you want?Or how quick do you want to run?
I agree,3.73 to 3.55s should be fine.Tom
For conversation.....
Calculate RPM for given MPH, Rear Gear Ratio and Trans Gear Ratio http://www.wallaceracing.com/calc-rpm.php 105 mph 1/4-mile trap speed (a guess) 28" tire 4.10 gear 1.1 trans ratio (presume a TH400 trans) Result = 5166 rpm (does not factor in converter slip and tire growth) Now ask at what rpm will the proposed engine make peak power at ? .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 01-28-2015 at 03:09 PM. |
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core.
Bwahahaha... good catch. I changed it.
And of coarse the mph was a wild guess. Not enough known about the proposed combo. Example of a combo, again for conversation only.... 4.210 stroke, unported alum heads, 10:1 compression, Performer RPM intake w/ Q-jet, headers and a 230 degree hyd flat tappet cam will make peak power at about 5200-5300 or so rpm. A similar roller cam might extend that some. And keep in mind where a combo makes it's 'peak' power rpm at is much different than where it will 'rev' to. Often 'reving' it a lot higher can be non productive. Also where it will be shifted at for best performance at the track. .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 01-28-2015 at 03:27 PM. |
Not really looking for a "quarter mile cam", I am more concerned with its characteristics on the street. Throttle response, best converter, will it work with e85?
I have a Ehead wideport combo right now (65ccchambers). I Just decided to try to make a driver out of my car, instead of a race car. I may even throw a Procharger on later!
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
Yea, it has 31's on it now but, they are slicks.
I would like to put some 19's on the rear. How are you doing Troy?
I guess I could run something like these
