Old 02-08-2015, 07:12 PM
GregL's Avatar
GregL GregL is offline
Default Full Throttle Travel?
Hi Guys,
Having a little problem with my throttle travel. Stock linkage with cable, original 7028265 Rochester carb. Pedal to floor only opens secondaries about 2/3 of the way. If I remove cable at carb I can easily open throttle to full position. Stock (new) cable has no adjustments and if I start bending things the idle will be too high.
Your thoughts?
Greg
Old 02-08-2015, 08:21 PM
frankyboy455 frankyboy455 is offline
Could it be the "sleeve" on the cable touching the "collar" when you're approaching full throttle ? Maybe you could take a look while someone's in the car pushing the pedal ? This looks like an aftermarket cable, is it ?
Old 02-08-2015, 08:57 PM
GregL's Avatar
Cable is correct for the car. Moves freely and does not hit or bind at the collar. I think I may need to bend the lower part of the pedal assembly upward.
Old 02-08-2015, 09:52 PM
If it will go WOT with cable connected at carb, when you pull it all the way back by hand, then yes you may have the lower gas pedal rod bent. Make sure to adjust it when the pedal hits the floor, you are at WOT. You dont want the carb to hit WOT and have a gap between the pedal and the floor, that's how linkages get bent or cables broken.
Old 02-09-2015, 12:19 AM
Dick Boneske's Avatar
Good advice TedRamAirII. Too many guys make the mistake of having the carb wide open with the pedal or linkage not fully bottomed. Broken parts follow--especially the throttle cable and carb throttle arm.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 02-09-2015, 09:57 AM
ANDYA ANDYA is offline
Also check to see that you don't have too much padding and carpet under the gas pedal as this will prevent the pedal from going all the way down.
Old 02-09-2015, 10:00 AM
rohrt rohrt is offline
I had to remove my pedal and bend it into shape to get WOT. Hardest part is getting that darn C-clip off.
Old 02-09-2015, 11:34 AM
68azbird 68azbird is offline
7 out of 9 of the first Gen birds I worked on needed pedal modifications to obtain full throttle. On one I used bronze bushings at the pivot. Helped take away a lot of slop associated with the plastic one.
Old 02-24-2015, 01:58 PM
GregL's Avatar
Re-bent the lower gas pedal rod, works fine now. Thanks guys.
Old 02-24-2015, 04:20 PM
silverbullet07 silverbullet07 is offline
The end of the throttle cable that connect to the gas pedal, I place a small lead fishing slip sinker on it to take up a little slop and that worked to open my throttle all the way open.
Old 03-26-2015, 06:17 PM
thefirebirdm@n's Avatar
thefirebirdm@n thefirebirdm@n is offline
Send a message via MSN to thefirebirdm@n
Hmmm I may have this problem too. I've tested WOT by having the wife sit in the car and press the pedal to the floor but always seems like when I reach in I can still turn the throttle back just a little bit more. I put an aftermarket adjustable cable (another long story) on it and have adjusted it 3 or 4 times. Pedal has always felt a little sloppy too. May have to take it out, replace bushings and see if it needs to be bent.
Is the pedal arm repro'd? The one in my car looks weird, not sure if its just the way the factory made them this way or not but at first glance looks like a piece at the end was remove but looking close also looks like it may have just come that way.
I'll post a pic later.
Jimmy
www.firebirdgallery.com
2002 WS6 M6 Trans Am - original owner
1973 Trans Am 455/4-speed
1971 Formula 400/400
1969 GTO 400/400 - 3rd owner
1968 Firebird Convertible 350/200R4
POCI - AAC
Old 03-27-2015, 01:28 AM
All the 1st gen birds were made so the carb didn't open all the way up on purpose. Thats why the bird had a HP rating of 335 HP & the GO had a 366 HP rating. Pontiac had a 10 HP rat per lbs rule & they did that so the bird didn't have the bigger HP because of the lesser weight of the bird. All it took was to bend the throttle bracket a bit to correct it & then the bird would have the 366 HP rating because the carb would then open all the way up. But it was done on purpose.
