Old 02-22-2015, 12:07 AM
Aus Goat Aus Goat is offline
Default 1968 GTO rear tires /offset
Guys I want to run 275 x50x15 drag radials on my car . They have a larger footprint than street tires so I think / know rubbing will be a issue .
Is anyone running 15 x8 rim with drag or larger street tires on a 68? Whats your offset and whats your clearance between edge of tire and rear fender lip .
I was thinking about 15x8 snowflakes or going with another set of Cragars SS
Craig
Old 03-01-2015, 11:34 PM
BLANK1's Avatar
BLANK1 BLANK1 is offline
I have 275/60R15 MT drag radials mounted on 15X8 with a 4 1/2" backspace wheels on my 68 GTO. Fit great, plenty of clearance at the lip.
Old 03-02-2015, 12:16 PM
6TEE8GTO's Avatar
6TEE8GTO 6TEE8GTO is offline
Lightbulb
Running 15X9 Centerline Auto Drags with a 28" tire along with Hotchkis lowering springs on my '68, and while the fit is VERY tight, I have not had any issues with rubbing, but I am using about every last centimeter of clearance. I have had 4 people in the car also and so far, so good.
GREG'S GOATS:
1970 GTO Judge
RA-III, 4-SPD & A/C. Power Windows, Power Seat, Power Brakes, Steering, AM/FM, 8-Track, Formula Wheel, Rallye Gauges, Remote Mirror, Numbers Matching. Assembled at Pontiac, MI Plant 5/26/1970.
1968 GTO
461 CI, RA-III heads, Hotchkis springs, UMI suspension, Bilstein shocks, 12-bolt 3.73's.
1966 GTO Ragtop
4-Speed, AM/FM, Original driveline.
