Test & Tune Ask questions about the features and functions of the Forums.
Old 03-05-2015, 11:23 AM
455rebel 455rebel is offline
Default Can't post in pm section
I can post in the forum section, but I can't reply to my private message.
Something wrong with the site?
455rebel
1970 amc rebel 4-door, faded blue paint,290 emblems on car, 455 under the hood.Turbo 400,3.15 gear.
Best so far 1/8 et,8.90 on street tires,
Since that I have added 400 heads.
I call it a rat sleeper.
Old 03-05-2015, 11:46 AM
Ccass's Avatar
Ccass Ccass is offline
Administrator
455rebel
It does appear that there is a problem with sending PM's in the system. We're looking into it.
Has anyone else been able to send a PM recently?
Old 03-05-2015, 01:49 PM
Thanks for the reply
Old 03-05-2015, 04:08 PM
Default ME TOO
Not sure...yesterday afternoon kept getting database error (same message as when your sever is down). My sent box shows it(4? of them) as sent and checking from other pc's and phone it shows sent... however I havent received any replies. (usually hear back pretty quick from recipient)
Bruce
Old 03-05-2015, 04:24 PM
63gpman's Avatar
63gpman 63gpman is offline
Same issue, also no notification when a PM comes through. The PM gets sent, but states that there is an error but when you check your sent box, it shows to have sent the PM.
Brad Hansen
65 Cat Ventura, 66 Cat Vert, 63 GP
Old 03-07-2015, 11:02 AM
straycat's Avatar
straycat straycat is offline
Still getting data base error. Don't know if messages are actually sent or if I'm receiving any.
Old 03-07-2015, 01:37 PM
cnc's Avatar
cnc cnc is offline
Nope just sent 2 pms and get data base error...but if u check your sent messages it's been sent..BUT are the recipients actually getting them????
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
Old 03-07-2015, 05:36 PM
Ccass's Avatar
Administrator
it appears like the PM's are going thru. Back to work on the problem on Monday.
Old 03-08-2015, 09:54 AM
Overkillphil's Avatar
Still happening here. Luckily the recipient had listed an email address in this case.
Old 03-10-2015, 11:58 AM
Still can't post pm.
Old 03-10-2015, 08:31 PM
3tas4me's Avatar
3tas4me 3tas4me is offline
I sent two last night and have no reply on either one.
1970 Trans Am
1971 Trans Am
1974 Trans Am
1978 Y88 Trans Am W72/auto
1979 10th Anniversary Trans Am
1984 Trans Am
1996 Trans Am WS6
1999 30th Anniversary Trans Am
2001 10th anniversary Firehawk #104
Old 03-11-2015, 09:54 PM
Still can't post.
Is this going to be fixed???
Old 03-12-2015, 10:21 AM
Old Goat Racer's Avatar
It took me 2 days to receive a PM.
Everybody knows somthin.
Nobody knows everything !
Old 03-12-2015, 02:03 PM
Scott Thelander's Avatar
I am also having the same issue
Guys are sending multiple responses thinking its not going thru ...
also defaulting as straycat mentioned..
also no email alert being sent stating I have a pm ....
thanks
Scott
Old 03-14-2015, 04:21 PM
unclescratch's Avatar
unclescratch unclescratch is offline
Red face error message
I continue to get the same deal today !! Hope my pm's go through!
Old 03-14-2015, 04:32 PM
Until the PM issues are resolved using email is probably best.
Old 03-15-2015, 08:14 PM
Still can't pm!!!!
Old 03-15-2015, 08:17 PM
It might be a couple of weeks or more before the technical issues are resolved.
In the meantime, email is your friend.
Old 03-16-2015, 02:58 AM
lust4speed's Avatar
Hey Bart, I sent a PM to you and it probably didn't go through. Could you email me and I'll re-send by email. Thanks
Address is [email protected]
Mick Batson
Old 03-16-2015, 10:16 AM
Received your PM Mick, twice actually.
