Where do these wires go? One has a plug on the4 end, the other has been pulled off. What are they for?
I'm guessing..just see which of the small ones is "hot" when the key is turned to the start position...any of the other small ones are going to feed juice somewhere else.
I'm sure somebody out there can post an appropriate wiring diagram to match your wires up to. JK |
Most likely the wires for the down shift switch on an auto trans option.
I have attached a copy of a wiring diagram I found on line (maybe you already have it). I used it when replacing my ignition switch and it seemed to be correct. It is also color coded so that helped out a lot in tracing the lines. I know it is not very clear on the screen, but it is an 11 x 18 document and I had to reduce resolution to stay under 300k limit. If you need something clearer send me your email and I will make a higher resolution copy.
My best guess is that those are the wires for the 2 speed automatic transaxle electrical throttle actuated kick-down switch.
