Just wondering if the ram air IVs came with the heavy duty cooling option or maybe the heavy duty radiator or heavy duty fan or both.Was the heavy duty cooling just the fan and radiator or what did it consist of.Im guessing the heavy duty radiatior was just the 4 core radiator from a car with air condtioning?Was the fan a clutch fan like that used on a car with AC?Any help would be much appreciated.Thanks
1969 Matador Red GTO Judge,1999 Ram Air Trans Am,1998 Daytona Pace Car Grand Prix,1959 Bonneville,2004 GXP Bonneville. |
Clicking off the RA4 engine, HDC was required, as was HD Safe-T-Track option. HDC consisted of the 4 core radiator, matching fan shroud, and in a non A/C only high performance application engine like the RA IV, the fan was the 5 blade factory flex fan. same deal with '68 Ram Air engines, as well as the '67 Ram Air engine.
Thanks for the info
Also I noticed that they have the extra baffle under the bumper to direct more air into radiator
true, the baffle was also used on factory AC cars.
have an NOS baffle for a 70 Pontiac A body. it is boxed as 3 pieces, two curved outer edge pieces, along with the long center section. Not sure if it is a production piece, or a service part. '71's and 72's used one long L shaped dark gray plastic baffle that is nearly always broken.
I have the 1969 baffle since I have a 69.Do you know if the ram air IVs also came with heavy duty battery or alternator also .thanks
It would have been nice if they would have come with the smaller air conditiong water pump pulley to circulate more coolant through the motor also
Does the heavy duty safe-t-track include the 12 bolt rear or what is it?Just a heavy duty posi case?I know the 455 1970 on up GTOs came with a 12 bolt because of the extra torque
No, 70 was the first year for the 12 bolt, 455 only. 69 had the nodular 10 bolt, 3:90 or 4:33.
WWW.SUPERCARCREATIONS.COM |
Thanks.I thought so but wasnt sure
Just to clarify, HDC was mandatory with RA IV not included in the price. Actually it was not directly related to the RAIV option it was mandatory with axle ratios of 3.90 or 4.33 regardless of engine or transmission choice. Also included in HDC was a set of baffles blocking the opening in the rad support for the frame rails.
HDC was also mandatory with AC but in this case was included in the price of AC, unlike HDC with 3.90 or 4.33 gears in the AC application it included a 7 blade clutching fan and modified pulley diameters to speed up the water pump.
My Break Away Squad 1969 Fbird (base OHC, 350, 400HO & Sprint Cvt’s - 400HO & TA ht’s) 1969 Custom S 2dr ht 1969 LeMans (2dr & 4dr ht & Cvt) 1969 LeMans Safari wagon 1969 GTO (2 Cvt, 2 ht & Judge ht) 1969 Cat (3 Cvt’s & a 2dr ht) 1969 Ventura wagon 2 seat 1969 Exec 4dr post 1969 2 Bonnie Cvt's & 2 wagons 1969 Bonnie Brougham (4dr ht & Cvt) 1969 Grand Prix 2 SJ’s 1969 2+2 2dr ht (Canadian) |
Thanks for the info.Very helpful.Do you know if ram air IVs also have a heavy duty battery or alternator
Those were stand alone options not included or mandatory with RAIV
