Old 04-06-2015, 11:02 PM
MCronkGTO MCronkGTO is offline
Default 67 Firebird 400 fresh restoration
With regret I am offering one of the nicest 67 Firebird 400 cars I have seen.
1967 Pontiac Firebird 400, complete professional rotisserie restoration with just over 400 miles. A combination of original and slight resto-mod. Data plate decodes as a Firebird Coupe with standard trim, Trim (272 H) black vinyl standard trim bench seat. The paint code is Q - 2 Verdoro Green (late spring of 67 color) with a black vinyl top. Accessory codes are as follows W – Soft Ray Tinted glass (windshield only), Z - 3 speed automatic transmission, F - 400 option (Firebird).
The car currently has aftermarket bucket seats (match nicely with original interior), tilt column, Pontiac reproduction wood wheel, factory GM reproduction 1968 Camaro console with 4 gauges (oil, temperature, gas, amps), factory GM Camaro shifter, factory GM reproduction Camaro speedometer and Tic-Toc Tach. GM Camaro D80 spoiler option (front and rear). Aftermarket radio with CD and USB/Aux inputs (no speakers holes cut in car). Vintage A/C and heat using factory controls and outlets. Other options added to car are Power Front disc brakes, power steering, and tinted glass all around. Black vinyl top was removed all new trim and emblems, upgraded radiator for A/C (looks stock), Turbo 400 transmission rebuilt with firm shift kit, complete new exhaust with Flowmaster mufflers and chrome turn downs. Rear axle completely rebuilt and new gas tank. All suspension bushings as well as front and rear end components are new as well as KYB shocks. Car has Boss 338 wheels 18x8 up front and 18x9.5 on rear with Toyo T1 Sport tires that have less than 200 miles on them. I have a nice set of restored reproduction Rally IIs available separately.
Engine is a 1968 GTO YS code with cast 16 heads and an Edelbrock Performer intake. Engine is completely and professionally rebuilt. It starts easily, runs flawlessly, and never runs hot. All under hood components are new or restored to as new. Car drives and stops excellent with no strange noises or issues.
$32k or best offer. PM me please as I don't check this site every day.
ID:	394755   Click image for larger version
ID:	394756   Click image for larger version
ID:	394757   Click image for larger version
ID:	394758   Click image for larger version
Old 04-06-2015, 11:12 PM
Default 67 Firebird
More pics
ID:	394765   Click image for larger version
ID:	394766   Click image for larger version
ID:	394767   Click image for larger version
ID:	394768   Click image for larger version
Old 04-06-2015, 11:19 PM
Default 67 Firebird
A few more
ID:	394772   Click image for larger version
ID:	394773   Click image for larger version
ID:	394774   Click image for larger version
ID:	394775   Click image for larger version
Old 04-27-2015, 12:42 PM
grivera's Avatar
grivera grivera is offline
For whatever reason I can't see the pics!
Will Rivera
‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears
'69 LeMans Vert, 350, #47 heads: work in progress
Old 04-27-2015, 01:21 PM
Doug Hopkins's Avatar
Doug Hopkins Doug Hopkins is offline
I think it has something to do with this site being down last week for several days. I am having the same issue.
Old 04-28-2015, 06:27 AM
wovenweb's Avatar
wovenweb wovenweb is offline
I'm seeing the thumbnails fine and they open when I click on them.
1971 Pontiac Trans Am Cameo White
1968 Firebird 400 convertible, Verdoro Green w/black top
1970 Buick Skylark Custom convertible(driver) Fire Red
Old 06-07-2015, 08:41 PM
SOLD! Went to the panhandle.
Mark
