Old 04-08-2015, 09:40 PM
z man z man is offline
Default 1968 ignition
anyone else able to start their GTO and while car is running ,remove key from ignition? it slides out completely while car stays running. long term problems??? z man
Old 04-08-2015, 10:51 PM
cortcomp cortcomp is offline
Probably no long term issue. A new ignition cylinder with 2 keys is like 11 bucks.
Old 04-09-2015, 12:20 AM
cuz68's Avatar
cuz68 cuz68 is offline
Mine is the same way.
Cuz68
Old 04-09-2015, 12:57 AM
pugslyx234 pugslyx234 is offline
nope
Old 04-09-2015, 01:09 AM
68gtoMN's Avatar
68gtoMN 68gtoMN is offline
Yes, exactly. Stuff wears out with time and use. Replace cylinder, problem solved!
'68 GTO 4-spd Hardtop (11)
'68 GTO Convertible AT (1)
'70 LeMans Sport
Land of Lakes Muscle Car Classic
Facebook Event
Facebook Wall (Kurt Smith,Minneapolis)
Old 04-09-2015, 07:57 AM
Half-Inch Stud's Avatar
Used to a "feature" that some of us folks would have, and also modify into follow-on Pontiacs.
I stopped doing that since my last racecar would drop the keys during the 60foot passage. Distracting & tiresome so no more.
Old 04-09-2015, 08:32 AM
nytrainer's Avatar
Mine does the same. I like it though.
Old 04-09-2015, 10:19 AM
I keep forgetting that you 68 guys have it in the dash. I haven't had a dash ignition gm vehicle that DIDN'T let you take the keys out. Love that 68 dash more than 69s for sure.
Old 04-25-2015, 05:26 PM
rememberfireball#22's Avatar
rememberfireball#22 rememberfireball#22 is offline
I have had a problem with my 68 for the last several years. There is a space in the fuse box that has no fuse in it. It is not labled, but I think it is the one on the bottom. Anyway the car runs great and all things work as they should. However, when I put a fuse in this spot the car will not quit running. You can turn the key off and take it out, and she is still running like the switch is still on. Have to put it in a gear and choke it down[4-speed]. Take the fuse out and everthing is good again. Anybody ever ran into this?
1968 GTO Numbers matching 400 H.O. 4-speed 3:55
1964 T-Bird 46,000 Actual Mile
1928 Model A
2009 Lexus
1981 Dodge D-100
1976 Cadillac Eldorado Convertible
19631/2 Ford Galaxie Fastback
