Old 04-12-2015, 03:58 PM
gtofreek's Avatar
gtofreek gtofreek is offline
Default What a difference a valve job can make
I just finished rebuilding some Edelbrock round port heads. Someone had valve jobbed them before with a 30° intake seat, and then somewhat ported them. I flowed them as they were when they came in, and again after I redid the valve job with a 45° seat, like they should have had. They had the exhaust seat cut with a radius cutter. I redid it with our radius exhaust seat cutter. I added a 30° back cut to the new Ferrea valves.
Here is what they did as they came in.
_Lift____In____Ex
.100____88____66
.150___131____94
.200___166___119
.250___186___142
.300___195___163
.350___208___182
.400___222___197
.450___233___209
.500___246___218
.550___254___222
.600___261___226
.650___266___229
.700___269___232
.750___272___234
.800___274___236
Avg.=__218__185
Here is after a valve job only.
_Lift____In____Ex_______gain/loss
.100____74____71_______-14/+5
.150___113___101_______-18/+7
.200___147___125_______-19/+6
.250___180___145________-6/+3
.300___209___166_______+14/+3
.350___236___184_______+28/+2
.400___255___202_______+33/+5
.450___270___211_______+37/+2
.500___283___217_______+37/-1
.550___292___220_______+38/-2
.600___298___223_______+37/-3
.650___302___227_______+36/-2
.700___305___229_______+36/-3
.750___305___231_______+33/-3
.800___306___232_______+32/-4
Avg.=__238___186______+20/+1
This engine will be turbo charged, and run a valve lift of around .600", so the average to his valve lift would be:
199/167 for the 30° seat, and 214/170 for the 45° seat.
I went on to tune up the port job and ended up with 316 on the intake @ .600" lift, and it peaked at 321. This is with a port match to the RAIV Fel-Pro # 1233 intake gasket. I have the flow sheet for it ported at work. Forgot to bring that one home. I can post it later.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 04-12-2015, 04:20 PM
Tom Vaught's Avatar
Boost Engineer
When they put the 30 degree seat on the heads they basically wound up with less flow than a out of the box e-head. Typical.
Good Job Paul.
Tom V.
Old 04-12-2015, 04:58 PM
gtofreek's Avatar
The only reason I can see to use the 30° seat is if they ran a low lift cam, like a stock 068 or something. The 30° really helps the low lift numbers.
Here's a couple of pics of the seat before, and after.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
Old 04-12-2015, 05:13 PM
Squidward's Avatar
Paul, I promise: I will let you do all of my cylinder heads.
Nice!
Can't wait to put my 47's on my 400. I'm breaking in my big valve (#12's) 350 as we speak. You cleaned those up.
I always get nervous on a break in. I already found a tranny cooler line I forgot to put a hose clamp on.
Old 04-12-2015, 06:37 PM
torqjunki's Avatar
torqjunki torqjunki is offline
Very nice. Easily the most important area for good flow. Bad valve job can negate some good port work. Good job Paul
1971 Base Firebird..505ci IA 2A Round port E-heads by Butler 348 cfm.. Comp street SR 266/[email protected] Victor intake/Quick Fuel Q950. 1 7/8" Dougs headers..3" mandrel bent exhaust with Hooker Max Flow mufflers, T-350 well built with 10" 4000 stall nitrous Continental converter..3.73 posi . Caltracs and 10" slicks. Belt driven water pump, alternator, Pwr steering and brakes,Flex fan. 11:1compression, straight 93 octane pump fuel. 10.35 @ 129.88 with 1.45 60ft N/A at 3700lbs race weight.
Old 04-12-2015, 06:53 PM
gtofreek's Avatar
Here is a comparison between my 670 heads, and these Edelbrock heads. I only have flow numbers to .450 lift right now. I have the higher lift numbers at work.
____670__________Edelbrock_____
_Lift_________CFM
.100"____71_________74
.150"____105.4______113
.200"____146_______147
.250"____185_______180
.300"____219.8_____209
.350"____247.1_____236
.400"____265.5_____255
.450"____273.8_____270
AVG,____189.2_____185.5
Pontiac Power! And to think this was done with only a 175 CC runner!
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
Old 04-12-2015, 07:04 PM
torqjunki's Avatar
Wow!
Old 04-12-2015, 07:34 PM
mgarblik mgarblik is offline
We can see the benefit of the 30 degree intake seat even when applied incorrectly to the E heads. The factory, with the much smaller ports, smaller throat and max lift of .407 would probably be better than a 45 degree most of the way to .400 lift. But what made sense in a stock head clearly doesn't when the lift increases and the port gets larger as proof from your re-work and the huge flow improvements above .200 lift. With the slow opening factory cams, they spent allot of time below .250 lift and the 30 degree seat worked. Sounds like an "old school" owner or shop worked on these first and assumed Edelbrock didn't know what they were doing with the 45 degree seat. For engines with .800 to 1" valve lift, I like playing with 50-52 degree seats. Helps on some, not on others. Your seats look nice. Serdi machine, Sunnen?
Old 04-12-2015, 11:21 PM
gtofreek's Avatar
We use a Sunnen seat and guide machine, VGS-20. We also use carbide pilots for a very concentric seat. We use the Sunnen VR-7000 valve refacer, which is chuck-less, and always faces valve concentric. We also use a Sunnen DRO setting fixture for setting the cutter bits to put the seat exactly where I want it on the valve.
ID:	395284   Click image for larger version
ID:	395285   Click image for larger version
ID:	395286   Click image for larger version
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
Old 04-12-2015, 11:30 PM
GOAT WHORE's Avatar
GOAT WHORE GOAT WHORE is offline
Always appreciate your posts Paul, thanks.
1969 GTO 4spd. Antique Gold/black, gold int.
1969 GTO RAIII 4spd. Verdoro Green/black, black int.
1969 GTO 4spd. Crystal Turquoise, black int.
1970 GTO 4spd VOE Pepper Green, green int.
1967 LeMans 428 Auto. Blue, black int.
Old 04-13-2015, 07:18 AM
steve25 steve25 is offline
Thanks for the post Paul!
Where these the 72 cc E heads?
Old 04-13-2015, 09:49 AM
gtofreek's Avatar
Yes they were.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
Old 04-13-2015, 10:36 AM
Tom Vaught's Avatar
Boost Engineer
X2 on the "Old School Owner/Shop"
X3 on Pontiac knew what they were doing with the head and valve angles for THEIR street applications.
Tom V.
Old 04-13-2015, 11:20 AM
The owner of those heads is lucky you where able to get a 45 seat back in there after it was cut down and back to a 30!
I guess they did not max out the OD of that 30 did they?
Old 04-13-2015, 11:36 AM
AC445 AC445 is offline
Default intake angles
Hello,I've posted this before,approx.35-40 years ago I took a broken 614 head to Jim Aller for flow testing.He checked intake angles in 5 degree incriments from 30 to 45 degrees.In this case with a port match and a 550 lift sft cam, 40 degrees worked best.So I think racers should be open to use whatever angles work best for their combination.
Old 04-13-2015, 12:11 PM
gtofreek's Avatar
When using odd angles, you are stuck with using stones to do the valve job, or buying a lot of custom cutter blades.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
Old 04-13-2015, 12:17 PM
johnta1 johnta1 is online now
True, but 40 years ago, they didn't have cutters yet?
(at least most machine shops didn't)
I can remember not being able to find stones big enough to do the Pontiac intake because most were for the SBC.
You could get some 2.19" for the BBC and regrind them to what ever size you needed.
Old 04-13-2015, 12:36 PM
Default valve angles
Hello again,I still have a Kwik-Way 40 degree stone in the garage.Seems like a bargain for 10-12 HP.
Old 04-13-2015, 01:05 PM
GRX's Avatar
GRX GRX is offline
Great thread. As always, your efforts sharing info and images here are much appreciated Paul. True about the odd angles. Brings back some memories of my "stone age" valve jobs. The older IH 345 with their 37.5 degree exh seat comes to mind. Always wondered about those.
Old 04-13-2015, 09:22 PM
I have the same Sunnen VGS20 machine and really like it . Wish it had a little more throat space for some operations like guide liners on some heads. I have the older Sunnen valve grinder and it is not centerless so I have to dial indicate every valve stem before grinding. Takes some time but does a nice job. Paul, have you tried the Joe Mondello signature cutters he developed a few years before his passing? I think they are just great for many applications and available from Goodson. A nice selection of 50 and 52 degree cutters there.
