Old 05-09-2015, 10:19 PM
gtoguys gtoguys is offline
Default 63 tach location
I have a 63 GP and I'm slowly adding accessories to it. I just purchased a tach and the correct adapter, but it didn't come with mounting studs. So my question is, what size studs, and does anyone have a dash that can measure the hole sizes for the tach? Also exactly where do I drill the holes for installation? Thanks in advance for the help.
Old 05-10-2015, 08:48 AM
ho421's Avatar
ho421 ho421 is offline
Brucee70 might be able to help you. Sent him a template last summer to help him locate the drill spots
Old 05-10-2015, 09:36 AM
tom s tom s is offline
Been a long time since I did one in a 63 GP.As I remember there is a stud and the other hole is for a bolt.I just moved the adapter around untill I got a good match on the dash,marked around it and drilled the wire hole with a 5/8 hole saw.It went thru very easy.Then drilled the holes.I do remember it was a PITA to get the bolt in to mount it.Maybe someone will have a more recent install.Tom
Old 05-11-2015, 07:36 PM
Thanks for helping, I didn't know what the wire hole size was. I will move the adapter around until I get a good location. Do you know which hole the stud goes in? or should I just use 2 studs and tighten them both?
Old 05-11-2015, 08:29 PM
Again as I remember it was a bitch to get my hand under the dash to tighten the bolt.I think you need one bolt to hold it to the dash.You might need to just get your hand up there to see witch one will be the best to be the bolt.Tom
Old 05-12-2015, 06:51 AM
Deadhead's Avatar
Deadhead Deadhead is offline
I think you will find that the adapter only fits in one place with the tach attached to it and have flush contact with the chrome bezel. It has been a while, but I think mine had 2 bolts that held it on. and a hole in the center for the wiring. I think I had to do one bolt from the top without dash pad on and one from under the dash.
"If you do everything you'll win"
-LBJ
13 Smiles per Gallon:
66 Bonneville wagon
66 Bonneville 2d HT - In perpetual progress
2005 GMC L-33
Old 05-12-2015, 10:14 AM
I know I did mine from under but as I said a huge PITA.Tom
Old 05-12-2015, 11:18 AM
Peter Serio's Avatar
Peter Serio Peter Serio is offline
Default 1963 Pontiac dash tach mounting
A couple of photos I have saved off of the internet. Credit to the original posters.
Name:	1963-64 Pontiac FS dash Tach PYs Revs.jpg
ID:	397495   Click image for larger version
Name:	63 Pontiac FS Dash Tach mount holes LH upper.jpg
ID:	397497   Click image for larger version
ID:	397498   Click image for larger version
Name:	1962_PontiacTachometer_Dash Bracket.jpg
Peter Serio
Owner, Precision Pontiac
Old 05-12-2015, 07:31 PM
astevens's Avatar
astevens astevens is offline
Those are great reference photos! Thanks
Old 05-12-2015, 10:09 PM
Great info. Thank you. I will be changing my dash, so installing, or tightening, the nut on the back shouldn't be impossible. Then I can install the correct radio and remove the cd player. Thank again guys.
Old 05-13-2015, 04:16 AM
strato gto's Avatar
strato gto strato gto is offline
Dash pad comes off fairly easy.You can get to the bolts from the top and look thru the windshield.
Old 05-13-2015, 06:14 PM
Ziggy Ziggy is offline
Here is a series of pictures that should help you. Access , with dash pad removal is the easiest. Here you go:
ID:	397627   Click image for larger version
Name:	63 Tach Dash Hole locations 001.jpg
ID:	397628   Click image for larger version
Name:	63 Tach Dash Hole locations 003.jpg
ID:	397629   Click image for larger version
Name:	63 Tach Dash Hole locations 002.jpg
Old 05-13-2015, 06:16 PM
Next
Name:	63 Tach Dash Hole locations 004.jpg
ID:	397631   Click image for larger version
Name:	63 Tach Dash Hole locations 005.jpg
ID:	397632   Click image for larger version
Name:	63 Tach Dash Hole locations 006.jpg
ID:	397633   Click image for larger version
Name:	63 Tach Dash Hole locations 007.jpg
Old 05-13-2015, 06:18 PM
Some more.....
Name:	63 Tach Dash Hole locations 008.jpg
ID:	397639   Click image for larger version
Name:	63 Tach Dash Hole locations 009.jpg
ID:	397640   Click image for larger version
Name:	63 Tach Dash Hole locations 010.jpg
ID:	397641   Click image for larger version
Name:	63 Tach Dash Hole locations 011.jpg
Old 05-13-2015, 06:19 PM
Hope these help
Name:	63 Tach Dash Hole locations 012.jpg
ID:	397643   Click image for larger version
Name:	63 Tach Dash Hole locations 013.jpg
ID:	397644   Click image for larger version
Name:	63 Tach Dash Hole locations 014.jpg
ID:	397645   Click image for larger version
Name:	63 Tach Dash Hole locations 015.jpg
Old 05-14-2015, 07:08 AM
Keith Seymore's Avatar
I did mine through the top as well, since I already had the dash pad off.
It would be oh-so easy if the windshield was out (...or if you had two elbows on one arm).
K
'63 LeMans Convertible
'63 Grand Prix
Old 05-14-2015, 12:11 PM
I thought about having surgery too have an extra elbow installed!! The pictures are great. It takes out all the mystery as for the location. The last picture you have is the tach in the car, the color of your car is exactly the same as mine. Again thank you for the help.
Old 06-26-2015, 12:32 PM
MOJO Catalina's Avatar
MOJO Catalina MOJO Catalina is offline
Send a message via AIM to MOJO Catalina
Great piece of tech help here. I currently have mine on a shortened console with the vacuum gauge next to it but have the mounting adapter for the dash and plan on doing it properly some day soon.
Sometimes towed but never trailered!
Old 06-26-2015, 11:50 PM
lilabner's Avatar
lilabner lilabner is offline
Need nimble fingers on a 61, but it wasn't hard to do.
Name:	IMG_2438 - Copy.JPG
Old 05-16-2018, 10:47 AM
I finally got around to installing my dash on my GP. Now I'm trying to figure out where the tap is for the tach light. I have a new harness from the tach and the blue wire has both male and female plugs on it in series. Where in the dash harness do I plug it in?
