Have some work to do up front and would love to pull the front clip off in one piece is this something that is done a lot ? Any step by step instruction I would think it would be pretty straight forward motor and tran are out but getting close to putting it back together . Would let me really get in there and detail the engine compartment Doug
1979 Trans Am 307 RWHP 380RWTQ 13.8@103 1979 400 Block, 1970 Heads, Unknown Cam, Comp Cam Lifters, Edelbrock RPM Intake, Hedman Headers, Holley 750 Carb, WFO Drop Base SOLD 1968 GTO convertable project. 400 auto with air. west coast car . Not started in 15 ..update now running (around block spinning tires all the way. Have a lot of cosmetic work to do winter of 17/18 1969 GTO 400 4 Speed this a complete project. Rebuild will start in spring of 2017. SOLD |
I do it like this (assuming that fit is already good);
1... pull the hood - leave hinges on the fenders (mark the outline of the hinges on the hood) 2... pull the valance 3... remove the grilles from the bumper and remove the bumper from the bumper brackets (leaving the brackets on the car, much easier after) 4... pull the fenders (marking the bolt positions on the cowl and rad support and bagging the shims for each bolt), I leave the tubs attached to the fenders. to reinstall do the reverse except that I like to first align the fenders nicely to the doors leaving them loose on the rad support, then install the hood and use the closed hood to "square" the fenders. Then the bumper should be just a quick left right adjustment, finishing with a tightening of the front fender attaching bolts and valance. Don't forget all the ground wires for the frame to fender tub and the parking lamp to rad support
My Break Away Squad 1969 Fbird (base OHC, 350, 400HO & Sprint Cvt’s - 400HO & TA ht’s) 1969 Custom S 2dr ht 1969 LeMans (2dr & 4dr ht & Cvt) 1969 LeMans Safari wagon 1969 GTO (2 Cvt, 2 ht & Judge ht) 1969 Cat (3 Cvt’s & a 2dr ht) 1969 Ventura wagon 2 seat 1969 Exec 4dr post 1969 2 Bonnie Cvt's & 2 wagons 1969 Bonnie Brougham (4dr ht & Cvt) 1969 Grand Prix 2 SJ’s 1969 2+2 2dr ht (Canadian) |
To directly answer your question... NO, it's not advisable to pull in one piece. The bumper and the brackets have to be off before removing the core support. The valance has to be off before removing the bumper brackets. It would be possible to pull the core support, inner fender wells and fenders together but you would gain nothing...
The above procedure from North is your best bet.
Paul FAST Automotive -The Pontiac restoration shop, not the fuel injection guys! I had the name first. My site... needs updated- www.fastrestorations.com 68 GTO's (RA II, RA I, HO, convert, Pro Street, Racecar, etc.), 2 69 GTO Judges, 70 GTO racecar -10.77 @ 124mph, 68 Tempest survivor, 3 03 Aztecs! |
