Old 07-11-2015, 06:06 PM
Mike S's Avatar
Mike S Mike S is offline
Default VP C12 vrs VP 113 results
I knew I would have a tuff time running 10.00 in the summer. I just need a tad so tried the 113 oxygenated fuel.
First run with C12 1.400 60' , 10.091/131.01
Drained the C12 out of the cell and put in the 113 then ran within a half hour of the first run. No other changes than fuel.
1.404 60' , 10.000/132.82.
Ended up running 9.99's/133 in the heat of the afternoon.
Just thought it could help someone looking for that last little bit.
I did qualify no 1 with that 10.000, ended up losing in the quarter finals.
Old 07-11-2015, 06:16 PM
PAUL K's Avatar
PAUL K PAUL K is online now
Did you change carb jetting? I while back we went from 110 octane to VP113 and gained 30 horsepower on the dyno, but we had to richen the carb a bit.
Go fast, see Elvis!
Old 07-11-2015, 09:54 PM
Mike S's Avatar
Only thing I changed was the fuel. Tune ups where the same.
Old 07-11-2015, 09:56 PM
PAUL K's Avatar
Interesting results. Maybe you will find more power with a bigger jet. I'm glad you found a gain that you were looking for.
Go fast, see Elvis!
Old 07-12-2015, 07:10 PM
You may have done the equivalent of leaning down 3-6 jet numbers with the 112.
Be certain you are reading plugs correctly. You dont want to get into pre-ignition or detonation.
This method works well. Easier on chassis dyno IMO.
http://www.wallaceracing.com/plug-reading-lm.html
Old 07-14-2015, 03:52 PM
SLICK1 SLICK1 is offline
Thumbs up
Nice findings!
(see it in action)
http://video.tinypic.com/player.php?v=2sbpmkm
Old 07-19-2015, 04:10 PM
Tim Corcoran's Avatar
Changing fuel usually requires a jet change too. Going from VP-112 to Sonoco purple required me to drop 3 jet sizes in my 65 LeMans.
Tim Corcoran
