Wiper switch with washer was working fine now can't get them to work. Switch seems very loose maybe worn out. Are you suppose to feel a click when you turn the switch on.The wiper motor, pump and harness is brand new. 2 Speed wipers with washer button. How do you replace these? Want to pick up a new one from Ames.
Thanks, Fred |
I have an old 66 switch out in the shop I can look at but, I think there is a small set screw on the side of the knob that holds it to the shaft.
Edit: I just looked at the switch and there is a small set screw that holds the knob on. Loosen the screw, pull the knob off then unscrew the bezel. Before you change out the switch try tightening the set screw. Sometimes they get loose and the knob may turn but the shaft doesn't. If the screw is loose you may have to turn it slightly while tightening to make sure it seats on the shaft properly. And, yes the switch does "click" when turned.
Remember no one is perfect. Everyone's butt has a crack in it! Last edited by fyrffytr1; 07-25-2015 at 11:00 PM. |
Thanks for the reply and pics. Got the switch out with no problem. Will order a new one.
Thanks, Fred Quote:
Check the ground first. I had the same thing happen. It had lost its ground.
-1967 GTO HO Restomod. PKMM 433ci, SilverSport T56 Magnum 6spd, Moser 9", SC&C and a bunch of other pro touring goodies - Build Thread http://forums.maxperformanceinc.com/...615847&page=23 |
How is the switch grounded? Is it grounded against the dash board when it's mounted?
Thanks, Fred |
I had a similar problem with my switch and after adding a ground to it. I have had no problems since. I used a very thin washer (that the switch went thru and was between it and the back of the dash, if that makes sense) that I had soldered a wire that was long enough to reach the main dash ground spot.
The wiper switch (and the headlamp switch) have a conjoined ground strap made out of a thin piece of steel. Here is a view from the backside. I don't have a photo of a '66 but '67 is basically the same.
