Old 08-13-2015, 05:01 PM
RR67GTO's Avatar
RR67GTO RR67GTO is offline
Default 66 Bonne Correct Fan,& Clutch & Side Molding
Good afternoon, looking at the green plastic flex fan on 66 Bonneville 389 Auto with AC, I know it's not factory. It doesn't have fan clutch either. Can someone please tell me if the 66 Bonneville 389 came with a five blade fan? Did it also use a clutch? I have to get rid of the ugly, green plastic flex fan. It still has the original shroud, and it's in fine condition. Also, along the side of this two door convertible, there is a think soft rubber or plastic molding. It has end caps, so pretty sure it's factory. It's faded gray/white, but looks like at one time it was either plated,or painted. Anyone have information on this molding, such as the correct name, and what kind of a finish was applied to it. Thanks friends. Mike
Build it fast, build it right, hold On TIGHT !!!
