Wanted: COMPLETE 4 speed swap for 1964 Catalina Wagon
Title says it all. Swapping from auto to manual so I need every nut and bolt.
What do you have? |
Are you going to use a console with the swap or just no console to make it very much easier & several hundred dollars cheaper. The hard & expensive part is going to be the console insert for the console for the 4 speed. Very few & far between & very expensive. The last insert I had & sold , I sold for $ 450.00 just for the insert , no shift boot or console lid & hinge. All the rest of the stuff is easy to come by & is not that expensive.
Have you checked Fabcraft?Like was said without a console it is WAY easier.Tom
I do not want a console, and I want to retain my bench seat
Brad has linkage,trans,flywheels clutch for sure,not sure about bellhousing.I saw a couple bells on ebay thou.Tom
The Z-bar for the G/P is a little different to which will be a little hard to come by. But all the other stuff you can get from ANY GM A-body.
I ended up picking up an entire 64 catalina with a 4 speed! whatever I don't use, will be for sale.
