1982-92 TA & FB TECH 1993-2002 TA & FB Tech is now part of the new Late Model Section of the PY Forums. Click this link to check it out.
Old 09-07-2015, 07:59 PM
THEGTOCHISM's Avatar
THEGTOCHISM THEGTOCHISM is offline
Question MSD optispark a better unit than Delco
Is it really worth the hundred dollars over a new AC-Delco on a street 95 trans am? Are they that much better?
70orbitorange
Old 09-07-2015, 08:08 PM
TTOP350 TTOP350 is offline
Not from what I've seen and heard.
http://www.fquick.com/garages/viewga...ewimg&id=74990
"You people have stood in my way long enough. I'm going to clown college."
-Homer Simpson
Old 09-07-2015, 08:45 PM
Default msd optispark
well that's one strike. thanks
70orbitorange
Old 09-30-2015, 07:31 PM
purchased two "NEW" ac Delco opti sparks off e rape. Both were rebuilt not new. One had it stamped on the box, unit, and paper work even. The other Was in a different box than the one in the listing. When i questioned the seller and told him 2 GM parts people said it was rebuilt., he said " that's all you are going to find now. So why lie in your add? Anyway got a new one from Petris Enterprises. Came with new vacuum hoses too. that's a 75.00 savings there. But It had a noise on the inside when i got it. But they made it good. Shipped me a new one fast and gave me a free 5 year warranty for free. Great people to deal with.
70orbitorange
Old 10-03-2015, 08:46 PM
Captainofiron's Avatar
Captainofiron Captainofiron is offline
I had an MSD unit, it was great, it ran for a few years then finally broke down because of the heater hose nipple leaking all over it.
Most of the first run problems have seemed to have been addressed.
From everything that I saw on LTXtech and LS1tech the bulk of the problems were people not installing the O-ring correctly
But from when mine finally did bite the dust, I sent it to MSD and they rebuilt it and did a few design updates to correct problems, the tech support engineers were really helpful and answered a ton of my questions
www.fquick.com/Captainofiron
68 Firebird 400, YC 400, Hbeam rods, ported 670 heads (2.11i, 1.77e valves), 1.65 RRs, Torker 2 intake, Nodular Crank, Eaton Limited Slip, Richmond 3.55 gears, M-20 M4
97 Trans Am WS6, LT1, M6, FLP LTs, Cutouts, Flowmaster catback, Jet Airfoil, K&N air filter, MSD Opti and Coil
14 Fiat 500e 83kW motor, 24kWh lithium ion battery, +2 sized summer tires
Old 10-13-2015, 11:03 PM
Drag Star Le Mans's Avatar
How well is MSDs warranty? I bought my opti from Auto Zone, unlimited life time warranty. It's been in 4yrs with no problems?
DragStarLeMans
Old 10-14-2015, 10:28 AM
I got mine from Petris Enterprises it has a 5 year warranty and uses the same optics as the AC Delco dist. Plus it came with new vacuum lines and check valve. that alone sells for 75.00 on E bay. great people to work with.
70orbitorange
Old 10-14-2015, 02:55 PM
quicksilver97ta's Avatar
I ended up with an AC Delco unit that I installed an MSD cap and rotor kit in. I think that's as bullet proof as it gets with the opti. Note: always use locktite on the rotor screws. That is what has failed on my previously unmodified opti's. Of course I'm exceeding the stock redline.
Old 10-14-2015, 09:01 PM
I bought mine when they first came out, 2007ish and last year they rebuilt it and upgraded it for 100 bucks with shipping
