Old 09-19-2015, 10:28 AM
carpoor carpoor is offline
Default What am I missing? 72' LeMans...
Installed the nose piece today, I have a stud on each side that goes to nothing. Is there a support bracket of some sort that I need?
1972 Chevelle SS 2dr hardtop 454 LS5 4 spd - "Pure Stock"
1969 Chevelle 2dr hardtop L72/M20 - my "retirement" project.
1968 Chevelle 2dr hardtop 6.0/80E - pro tour-ish
1972 Monte Carlo turbo 6.0/TH400
2001 Silverado RCSS LQ4/80E swapped, cam, headers, FBO.
1972 E lCamino SS AFR headed 454/TH400 - the old man's project
Old 09-19-2015, 10:41 AM
indymanjoe's Avatar
indymanjoe indymanjoe is online now
Pic of mine from same angle and i dont have a stud.
ID:	408496   Click image for larger version
I am the Thread Killer!
Old 09-19-2015, 11:28 AM
Default '71 and '72 standard nose LeMans differences
The leading edge of the top plate on the '72 core support is different than the leading edge of top plate on the '71 core support.
-when one attempts to bolt a '72 (metal) header panel on a '71 core support, usually the body guy cuts notches in the leading edge of the '71 top plate. The original on my '71 HO post car had suffered this treatment, and I ended up correctly swapping a nice ' 71 top plate back onto it.
-the '72 core support leading edge was redesigned to take the '72 metal header panel, but the '72 core support will also accept the '71 FRP (fiberglass) header panel, it's just a few attachment spots will not be used. Most likely, you have a '71 FRP header panel on a 72 core support.
Old 09-19-2015, 11:59 AM
Thanks guys. It is a fiberglass header panel, was on the car when we got it. But, a lot can change/happen in 40 years. (1972-2012) We have a spare 71' header panel, core support, top plate. I'll have to compare it sometime.
