Old 09-20-2015, 07:45 PM
dirtbkr89 dirtbkr89 is offline
Default pushrods rubbing??
So after assembly on my 461 we noticed my pushrods are rubbing on my edelbrock heads. I thought they were supposed to clear 1.65?? Anyone else have this issue?? I am running solid roller and harland sharp 1.65 rockers. Pushrods were measured and ordered the correct lenghts
Old 09-20-2015, 08:05 PM
tom s tom s is offline
What dia push rods?Tom
Old 09-20-2015, 08:06 PM
Old 09-20-2015, 08:16 PM
rod cole rod cole is offline
My 1st gen edelbrocks rubbed at the bottom of the tubes quite a bit with a flat tappet cam. 5/16 rods thought I was the only one Rod
Old 09-20-2015, 08:19 PM
Tim Corcoran's Avatar
You got two choices, remove the heads and have the pushrod holes enlarged or switch to 1.5 rockers. I can understand your frustration as you would think the heads should clear.
Tim Corcoran
Old 09-20-2015, 08:25 PM
Yeah i already have It apart and going to To open up the holes. Its just crazy everyone I have talked to says there's clear
Old 09-20-2015, 08:50 PM
How much is safe to remove?
Old 09-21-2015, 06:42 AM
steve25 steve25 is offline
Tons of meat there at the bottom ,you can grind off a easy .060" with room to spare
Old 09-21-2015, 09:53 AM
Rob B's Avatar
Rob B Rob B is offline
Ditto. Had to clearance the sides on a couple of the holes on my 2nd gens when I put them on my aftermarket block. Still running a flat tappet.
74 GTO Bracket/Street car and another 74 for the wifey to race with!
70 GTO 400, 4 spd, #'s matching and a little to nice for me to own.
Friendship is like peeing your pants..everyone can see it but only you can feel the warmth!
Old 09-21-2015, 10:01 AM
PONTIAC DUDE's Avatar
Wink
A sight rub won't hurt anything and will also help control flex.
Old 09-21-2015, 11:26 AM
It's not a slight rub once I really watched it. It was almost flexing the pushrod. Do the Louis tools work on the e heads
Old 09-21-2015, 11:37 AM
RA462's Avatar
RA462 RA462 is offline
Careful. I had the same issue with my High Ports (but at the top of the pushrod hole) when I changed to a higher lift camshaft. Cost me broken lifter bore and junked a block I had 2K in.
Todd Sedlmeier
Who ever thought pinewood derby cars would lead to this!
October 2004 HPP Shootout participate
http://www.highperformancepontiac.co...out/index.html
86 Grand Prix
535 High Port 8.93 @ 153
65 GTO
433 High Port 12.04 @ 113
Old 09-21-2015, 11:51 AM
Mike Davis's Avatar
What wall pushrod?
Spring Pressure?
I have seen allot of pushrods rub the head due to the pushrod flexing.
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
Old 09-21-2015, 12:19 PM
1-Piece .083 X 5/16 .040 Oil Restricted Chromemoly Pushrods
440 lb spring pressure
Old 09-24-2015, 07:21 AM
grandville455's Avatar
grandville455 grandville455 is offline
That kind of pressure i would be using .116 wall, IMO
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
Old 09-24-2015, 07:44 AM
JSPONT's Avatar
JSPONT JSPONT is offline
X2^^^^ A friend of mine had such bad push rod flex it looks like the push rod was touching the head the hole way down. There was a thread on here somewhere. I went to 3/8 manton push rods. Heads had to be clearenced and new guide plates.
Old 09-24-2015, 08:59 PM
Mike Davis's Avatar
Agree, that is why I asked the thickness. Had the same issue the op is having using .083. Changed to Smith Bros .116- problem gone and the car picked up .10
