Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 09-23-2015, 04:02 PM
allryz70 allryz70 is offline
Default 70's GTO Street/Strip Used Performance Parts
Hey guys/gals if you know of anybody building or converting a stock GTO over to a Street/Strip car then I may have some used parts that might interest them. All parts came out of our old 70 GTO Judge (low 11sec car) that we use to somewhat race and drive very little on the street. My opinion the parts are in excellent shape...like new. Below is a list of parts if anybody is interested.
Call 815-441-7073 or email ryanw "at" ppind.com
-12 Bolt Rear End (Eaton Posi, Strange axles, disc breaks, mult. gear set, sway bar, adjustable control arms, etc.)
-Cragar Aluma Star Wheel with Hoosier Quick Time Pros (rear only)
-Stock size Griffin Alum. radiator
-Rodney Red Duel Electric Fans w/ housing
-Hay Clutch and or Centerforce Clutch
-Hays Flywheel (insertable)
-Lakewood SFI Bell housing
-VFN Cowl Hood (Bolt on with springs, painted Black, w/ low tension springs, I believe it is a 4 cowl, will include "air pan")
-Performer RPM Intake (had on 6x heads. Heads were shaved)
-Fuel Cell with Trunk mount and Mallory 140 fuel pump (I believe it is a 15gal)
-TCI TH400 Trans
Thank you for looking!
Old 09-23-2015, 04:04 PM
Please list a price for each item you have listed here.
It's a requirement to sell here, thanks for your your cooperation.
Old 09-23-2015, 05:02 PM
My apologizes....I didn't see that as a requirement. I will update as soon as I can
Old 09-23-2015, 05:16 PM
Region Warrior's Avatar
Dib's on the bell housing if I can afford it.
Pm sent.
Old 09-24-2015, 11:36 AM
Update: Pricing is attached. All pricing is negotiable.
-12 Bolt Rear End (Eaton Posi, Strange axles, disc brakes, mult. gear set, sway bar, adjustable control arms, etc.). ($2,250 for package)
-Cragar Aluma Star Wheel with Hoosier Quick Time Pros (rear only) ($275)
-Exact Fit Griffin Alum. Radiator ($300)
-Rodney Red Duel Electric Fans w/ housing ($300)
-Hays Racing Clutch with 1 disc ($450)
-Centerforce Clutch with 2 disc ($150)
-Hays Billet Alum. Flywheel ($300)
-Lakewood SFI Bell housing (with fork, motor plate) ($350)
-VFN Cowl Hood (Bolt on with springs, painted Black, w/ low tension springs, I believe it is a 4 cowl, will include "air pan") ($400)
-Performer RPM Intake (had on 6x heads. Heads were shaved) ($125)
-Race Fuel Cell (Clear/Foam) with Trunk mount bracket and Mallory Comp Series 140 fuel pump (It’s either a 12 or 16 gal) ($225)
-TCI TH400 Trans w/ Trans Break ($1000)
Old 09-24-2015, 01:37 PM
Fast 69's Avatar
Fast 69 Fast 69 is offline
More info on wheels please. (size, lug patter and backspace)
Old 09-24-2015, 01:44 PM
mrrat1 mrrat1 is offline
pics of the radiator please........stick or auto?
Old 09-25-2015, 05:52 PM
Wheels are 15x10. The back spacing is pretty deep and I believe it is the most you can get. The Hoosiers are 28x11.50-15. This is pretty much the biggest wheel/tire you can get under a stock GTO and still have the lip on the inside of the rear fenders. We actually ran a wheel spacer on top of it to make it work. Since it was pretty tigth there is some scuffs on the tires as they would rub slighty make a sharp and fast turn. Standard lug pattern.
Old 09-25-2015, 05:54 PM
mrat1....plesae send me a PM with your standard email address or cell number and I will get you some pics. Thank you!
Old 09-25-2015, 08:10 PM
Fast 69's Avatar
Interested in the wheels. I need to know the exact back space tho. Thx.
Old 09-25-2015, 08:32 PM
I stand corrected. Wheels are not Alunma Stars (they are not a two piece wheel). I was informed they would be a cragar glidden. Sorry for the mistake
Old 09-25-2015, 09:29 PM
Goatster69 Goatster69 is offline
PM on the way for intake.
Old 09-25-2015, 10:07 PM
I should have done more homework before posting these wheels!
They are 15x9 with 5-4.5" bolt pattern and has a 5.5" backspacing.
Sorry for the confusion!
Old 09-28-2015, 04:54 PM
PM sent with email...........
