Old 11-15-2015, 01:52 PM
Brandn74 Brandn74 is offline
Default Better head for nitrous
Would my 340cfm e heads work well on a 535 with heavy nitrous or should I get a different head?
Old 11-15-2015, 04:17 PM
Tom Vaught's Avatar
Boost Engineer
How quick do you want to go?
Tom V.
Old 11-15-2015, 05:57 PM
Tom I'm trying to get in the mid 4's in the 1/8.(4.70-4.50) I don't have the 535 yet but I have the heads on a 474 right now.
Old 11-16-2015, 12:53 PM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
how light is your car?
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046 jet
First ultra street/ultimate street NOS car to get into the 4's!
1.079 4.559 153.23.
3100 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
T2TTFMF!
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
Old 11-16-2015, 02:58 PM
Tom Vaught's Avatar
Boost Engineer
Jeff can give you some good advice for sure.
Tom V.
Old 11-16-2015, 05:00 PM
Sorry for the late reply the car with me in it is 2701.It's a stock suspension 85 mustang with a powerglide transmission 3:90 rear 28 inch tall tire
Old 11-19-2015, 07:36 AM
Elarson's Avatar
Elarson Elarson is offline
Lots a variables affect your final results. But I think 340 cfm is going to make your goal hard to reach. You can't just keep jetting the nitrous bigger and keep making gains. You will find the heads will choke and determine a practical ceiling. You'll likely need something over 400 cfm, and there are choices now that go significantly beyond that.
Eric
Old 11-20-2015, 01:49 AM
Thanks Elarson.I talked to the guy at EIC motorsports and he told me the same.Time to upgrade.Thanks for the replies.
Old 11-21-2015, 10:25 AM
wreckmastr's Avatar
I'll sell you a set of EIC motorsports 400+ cfm E-heads
ET/mph talks, bullchit walks.
6.98 @ 199mph
4.53 @ 164mph
Old 11-21-2015, 11:17 PM
mgarblik mgarblik is offline
I have found after running E-Heads and Tiger Heads with heavy N20 loads of up to 600 HP, that the Tiger heads lasted longer between head gasket failures. The E-heads are just so light, thin and have so much water jacket that they eventually "hump-up" and fail between the center cylinders where the 2 exhaust valves reside. We ran copper gaskets with o-rings and steel step washers at each head stud. We could get 10-15 passes out of them and then the heads had to come off and be resealed. That was at 1350 net HP. The Tiger heads with the same tune-up would go 20-25 passes and then have the same problem. But that was at 1500 net HP. The e-heads were 370 CFM and the Tigers 425 CFM. The Tigers made 100-110 more HP NA than the E-heads we were using. A couple of additional factors. We didn't run Cometic gaskets, they might help. We also ran a wet deck, a dry deck might help. Finally, the copper alloy insert Calvin Hill markets and installs would certainly help either head hold a gasket with big N2o use. If I had it to do all over today, I would take a close look at the Ram Air V offerings out there. Getting those damn center exhaust valves separated for nitrous or supercharged applications would have to help the gasket situation. My proof of that is the fact we are still running the very first set of copper gaskets on our Ram Air V based nitro engine after 4 years.
