Old 11-29-2015, 09:03 PM
pontiacman63383 pontiacman63383 is offline
Default Camshaft/valve train selection help
I'm new to building performance engine but not new to cars. Been turning wrenches professional for 10+ years now. The motor for my 69 lemans is at the machine shop as we speak getting rebuilt. So I need to figure out what cam and valve train I'm going to put in it. The motor is a 400 that is going 30 over and getting a strokes kit put in it. Heads are a 73 4x heads. (98 cc). Flats top Pistons, my engine guys says should be 9:1 compression. Cars transmission is a 69 m22 and rear is 3.73. I'm looking for good power and would like a rough idle but not to where it's not fun on the street. I'm open to ideas, what do you guys think I should go with cam wise and what size rockers? Thanks for the help
Old 11-29-2015, 09:06 PM
unclescratch's Avatar
unclescratch unclescratch is offline
Default VALVETRAIN
Pontiac's 744 cam w/1.65 rockers
Old 11-29-2015, 09:46 PM
68WarDog's Avatar
68WarDog 68WarDog is offline
With 98cc heads with a "stroke" 400 and 9:1 c/R , I'm guessing about 455 ci. The 744 IMO is too small, I would try something like a 041 and a little more if you spend for porting. Good luck
Old 11-29-2015, 09:59 PM
If you look at any of my posts you'll see I'm a fan of the RA IV cam. I use the Crane blue print RA IV cam in a lot of my builds. It will give you good power & a good sound & a bit of rough idle, but not bad. Also use the 1:65 rockers as it give the full lift out of the cam which it is designed for. With the 3:73 rear end it will put the best use of that cam too.
Old 11-29-2015, 11:14 PM
Strokes kit is by eagle. 4.25 stroke. Again going off my engine guy he says it should be 461 ci. (Don't know if that will make a diff in your choice) You guys are recommend factory grind cams, is there a place I can look up the pics for these cams to get in idea as to what they are? And why factory grinds? Do aftermarket ones not work as well or would they just be better with my setup?
Old 11-30-2015, 01:42 AM
68WarDog's Avatar
Sorry, wasn't trying to be literal about an 041 hft. Just making reference to cam size only. Whichever you choose, think roller.
Old 11-30-2015, 03:13 AM
Will Will is offline
The factory grinds are amazingly effective, the PMD engineers really knew what they were doing.
Will your budget allow a roller cam? If so, that's the way to go.
In an engine that size you can easily go to mid 230s @ .050" on the intake side with a 112 lobe separation to get a nice wide powerband out of that big engine.
Old 11-30-2015, 03:45 AM
mnfatcat's Avatar
mnfatcat mnfatcat is offline
Really like the comp cams XE284, the Dude recomended it, same motor as yours with a different head combo. Sounds awesome thru 3'' pipes w/o a crossover, oval Dyno Max Ultra Flows.
68 Cat 2 dr sedan 461ci 670 heads XE284H 850 Holley
493/525 wide ratio 4sp 3:42 posi 13.07@105 full exhaust
Old 11-30-2015, 03:59 AM
I have/had a 462 in my 73 GTO with 3:73 rear gears , the engine consists of a 455 at 30 over, with SRP forged pistons, E-heads Performer RPM intake, Crane Blue Print RA IV Cam, 1:65 roller tip rockers, M22 4 spd, Pertronix ign, (unit # 1) Eagle forged H-beam rods, a new Eagle cast crank, RA IV cast iron exhaust , topped off with an 800 cfm Q-jet. The car before I had some concerns with it (blew a head gasket) & caused some other concerns to. But it ran 11:72 @ 122 mph in my 73 GTO . Thats the 1/4 mile. I like the RA IV cam as mentioned before Pontiac knew what they were doing when they designed that cam. There are some that I will same are as good but I stay with what works. As far as roller cams , they are good but they do cost a lot of money extra to use. If you were to go with the RA IV flat tappet cam , & then if you go to a roller cam with the same grind or any other, you'll add about $ 1500.00 to your build as the cam is more then you need the lifters, different push rods, different rockers & the possible machine work to use the roller cam & lifters, it all adds up very quickly for a roller set up. If you use the break in oil & do the proper break in of the flat tappet cam you won't have to go roller. Thats why most go roller because their afraid the cam will go flat during break in. But if you do it right you won't have any problems at all. Just use the break in oil & you'll be fine with a flat tappet cam. I have the RA IV cam in my 400 60 over thats in the car right now & it runs & sounds great. Same car, with the 400 60 over the car went 12:48 @ 114. I used all the parts from the 455 in the 400. So the cam works.
Old 11-30-2015, 04:01 AM
krisr's Avatar
krisr krisr is offline
I ran an XR288HR in my 400 with #16 heads and tomahawk intake. Fuel injected though, it ran awesome! The heads were the limiting factor as I couldn't put anymore than 28deg timing into it otherwise it'll rattle all the way down the road. Have switched to a e-heads and a cam with 6deg more duration at 0.050 and it runs pretty good so far for a half dialled in combo. You have cubic inches on your side aswell as good rear gear ratio, don't be scared to cam it.
'71 Holden HQ Monaro - 3850lbs race weight, 400c/i - 11.4 @ 120
'66 Pontiac GTO - 389, 4 speed street cruiser
Old 11-30-2015, 04:39 AM
mnfatcat's Avatar
Is there a Pontiac Kool Aid that I'm not aware of ? Love my Poncho, but I don't genuflect at the altar of 50 year old cam technology.
Old 11-30-2015, 04:46 AM
lust4speed's Avatar
I do a lot of engine builds for our car club members. Some of the builds are to replace flat cams, but most are to step up performance. Most of these engines are just a few years old and pretty low mileage. Some were put together by the owner and some by professional shops. The punch line here is that in the last two years I haven't pulled out a flat tappet cam that I would have put back in - all were showing signs of failure. Some might have lasted another 10,000 miles, but there were a few where I don't know why they were not making noise yet. Everyone swears that they stuck to recommended break-in procedures, and were running a ZDDP additive.
You've spent good money on the stroker kit and the build sounds great, and I would suggest spending the money for the roller cam and not have to worry about when (not if) the flat tappet was going to fail.
I would follow Dave at SD Performance's suggestion and go with the Stump Puller for a mild iron head. He generally recommends the Old Faithful for better breathing aluminum heads, but the Stump Puller for iron heads. Another reason that the stump puller will work out good is the close ratio trans and 3.73 rear isn't a lot of gear in first and the Stump Puller roller cam is going to help drivability.
Here's a photo of some of the failed flat tappet cams waiting to go to scrap - no rollers in the group.
Mick Batson
Old 11-30-2015, 07:34 AM
Cliff R's Avatar
Cliff R Cliff R is offline
Another vote for a roller cam upgrade. Below are back to back dyno sheets same engine with only a cam change.
It was first assembled/dyno'd with a the Comp XR276HR cam, pinged on the dyno, idled "****ty" and didn't make much power.
The second cam is one I recommended for the shop to replace it with. It's a custom grind from Comp, basically the Old Faithful on a 114LSA.
The 455 used 250cfm iron heads flowing 250cfm, nothing else "exotic" going on with it, Eagle stroker kit and tight quench........Cliff
Old 11-30-2015, 02:09 PM
GRX's Avatar
GRX GRX is offline
Feel compelled to state the obvious and mention a good set of valve springs. Ones that will handle the new cam & added lift of the 1.65 rockers.
1969 GTO hard top ~ Std bore 400, '70-RA3 block, 670 heads, Bal. & Blue... M22, 12-bolt w/3:55s
Old 11-30-2015, 03:40 PM
Lee's Avatar
Lee Lee is offline
I agree with Mick and Cliff, go roller cam.
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
Old 11-30-2015, 04:09 PM
jonmachota78's Avatar
jonmachota78 jonmachota78 is offline
X2 and be prepared if you go Old Faithful with 1.65 rockers, you're looking at .660" lift. Have your heads been clearanced for 1.65 rockers?
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports,
3" pypes, Hooker 1 3/4" headers, hydraulic roller,
10" Continental, 3.42 gears
11.5 @117.5mph 3900lbs
([_|_] ##\|/##[_|_])
Old 11-30-2015, 09:16 PM
Thanks for all the inputs guys. I was really hoping to go with a flat tapped hydro because its about 300 bucks more in lifters alone (not to mention the other add-ons ill need) but I have spent the money already so no need to cheap out now. It seems we all agree that 1.65 rockers at the way to go. As of now the heads are completely stock. I planned on sending them out for a mild port and polish to get them to flow a bit better as I know the heads are what is going to hold back the motor the most at this point. When you say they need to be clearance what do you mean? Also everyone seem to like "old faithful" where can I buy/get more info on this particular cam. Also side note, anyone got a good set of used roller lifters for sale? lol
Old 11-30-2015, 09:34 PM
tom s tom s is offline
Of any item I would not use is used roller lifters.Used cams but I would hold back on used lifters.JMO,Tom
Old 11-30-2015, 10:01 PM
krisr's Avatar
I've reused my hyd roller lifters on 2 different cams now without issue, but I know their history and checked them each time. Best thing I found with rollers vs flat tappet followers. Going a roller now can give you that reusability of you want to change later, no break-in, better cam design etc..
Old 11-30-2015, 11:40 PM
gtofreek's Avatar
gtofreek gtofreek is offline
I've installed this cam here[http://www.lunatipower.com/Product.a...=1777&gid=287] in several 455's, and 462's. They run real good in combos like yours. It's similar in .050" specs to the factory RAIV cam, but has more low end power, and a broader power band than the RAIV blueprint cams out there. It will have a slightly lopey idle, and make good power from 2000-6000 rpm or more.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
