Put new after market hood hinges on a 65 GTO, now the hood will not stay up. Put the original springs back on. H E L P.......
First, why did you replace the original hinges and springs? The hinges can be rebuilt and rebushed to BETTER THAN NEW specs, with closer tolerances. "Bill"!
If so, try new springs. Old ones may be too weak. I bought repop hinges and springs last year, and they work fine.
66 GTO, 495, M22, Strange S-60 w/4.10 Sold new at Royal Pontiac (Dealer# 07-679) 70 Formula 400/auto |
Old hinges were somewhat bent, not allowing for hood alignment. If someone wants to rebuild orig hinges, so be it. I opted for rebuilt. Original springs seem very strong. Any ideas why hood will not stay up???
That is why they are rebuilt. lack of lub over the years. hood doesn't fit right. Have to push, pull, twist to get the gaps correct. Assembly plant did not do that when installed new. Repro never better than original. "Bill"!
New hinge geometry may not be correct. |
I would say that new springs would take care of your problem. On a side note, the old springs can be repurposed to hang a bench swing
http://forums.maxperformanceinc.com/...hlight=rowland
http://forums.maxperformanceinc.com/...hlight=rowland A couple of hood hinge discussions.. "Bill"! |
I think Bill may have it right concerning the hinge geometry being off with the repro hinges.
I have changed the springs from a parts car I have, and the hood still will not stay up. |
Call 818 845-3574, Rowland Hall. It will take longer to ship to California and back than it takes him to repair. And the price is cheap... Bolt them on, shut the hood. May have to adjust the cowl gap. That's it. DONE. "Bill"!
Get your originals rebuilt by Rowland. You'll be glad you did.
"What ain't no country I ever heard of. They speak English in What?" - Jules Winnfield ------------------------------ 2015 Jaguar F-Type 340hp Convertible, Polaris White/Ebony Interior 1964 Pontiac GTO, Tri-Power, 4 Speed, Grenadier Red/Black Interior 1965 Chrysler 300 Convertible, 383/727TF, Factory Air, Spanish Red/Red Interior/White Top |
I agree rebuilding originals is the only way to go. Does Bill have them cad plated as well?
I think I misled everyone by saying I had rebuilt hinges when I meant to say repro. My orig ones were warped and thrown away by the guy that painted my car. Would it be a waste to send repros to Mr. Hall??
Thanks so much for all of your responses. |
421-6speed, that question opens a can of worms. My hinges are natural. Rowland has rebuilt hinges for over 25 years for ALL types of cars. He told me they were natural, BUT if you read the threads I offered several posts earlier, you saw some disagreement, soooo that is your decision!
Davidgto, call and ask him. He is easy to talk to. "Bill"! |
Thanks Bill, I will call.
There are two other places I found also.Depending on how concern you are about detail. You may want to ask questions.
do they use the spiral headed rivets and are they over sized heads. Some of the rivets also have letters stamped in heads. I had mine phos coated . what I consider to be correct. You can do that your self with magnanze (gun blue) http://www.hoodhingerepair.com/ http://www.sms-auto.com/ |
What led you to believe they were warped? Because the hood wouldn't lay flat in the back? If so, they were worn, not warped. It's a common epidemic with these 50 year old hinges. Your best bet may be to get a set of used hinges off eBay and send them to Rowland for a rebuild.
The hinges on this 60 Ventura I am currently doing are gray with no rust or corrosion but still could look much better so I thought maybe they were silver cad. Guess I need to call Roland and see what he has to say. Thanks for the information. |
IMO to send repos out would be throwing bad money after bad money. You need to locate a good set of original hinges. Good Luck
Just a note to OP, I saw in the classified ads a pair of '64-'72 hood hinges for $80...just sayin'. Maybe good timing, eh?
Thanks guys. Appreciate the info and opinions.
dave |
