So I'm finishing up adhering new upholstery on the rear armrest panels, and start to install the courtesy lights and notice just one side has the hole and tabs. So did I get a metal panel from a car without the light option? I'm assuming both sides had courtesy lights like my 68. This will be fun trying to cut the metal after the vinyl has been glued on.
'67 GTO Convertible - a couple extra HP, On the road! '68 GTO Convertible - in frame off stage '67 GTO Hdtp, HO 4 speed - next |
Possibly a base Tempest side panel.
Measure out the location and cut an X to gently peal back the vinyl and then you could use a Dremmel type cutout tool ?
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car.
Thanks Jeff, that's probably the plan, careful surgery with a die grinder. It would have been so much easier if I had checked fit on both panels, before putting on the upholstery.
