Old 12-19-2015, 10:44 PM
gto_ron's Avatar
gto_ron gto_ron is offline
Default build sheet question
Hi all,
In the production instructions box on my build sheet does anyone know what the 'SR' stands for?
My car has an 'SR' block, it has the correct casting number 9773155, is there any connection?
Ron
64 GTO convertible, gone but not forgotten
76 CB750K
72 CB350F
" why yes, I am old school, so what?"
Old 12-19-2015, 11:18 PM
MikeNoun's Avatar
MikeNoun MikeNoun is offline
Ron, I believe the SR stands for Special Ratio. I have several examples of Pontiac-plant built 1964 GTO with 3.90 gears, and they all have the same SR PN 174 175 in the Production Instructions box, and AXLE 39 10 APP in the bottom box.
Mike
Old 12-19-2015, 11:33 PM
gto_ron's Avatar
Thanks Mike, that never occurred to me.
Ron
76 CB750K
72 CB350F
Old 12-20-2015, 09:49 PM
riggsjr riggsjr is offline
I have a 1965 GTO and a SR casting # of 9773155 also. I thought SR stands for SERVICE REPLACEMENT?
Old 12-20-2015, 10:40 PM
jarhead's Avatar
jarhead jarhead is offline
It's my understanding that they are the last 3 digits of the front and rear Heavy Duty or Handling Shocks as in 3178174 and 3178175. The other choices would be Standard or Trailering 3186908 and 3186909 or Superlift RH 3178552 and LH 3178551.
More pictures of my former Goat:
http://www.barrett-jackson.com/appli.../w_search.aspx
My old car is listed in the 2007 Scottsdale Auction, Lot #1016 - $60K
And in the 2008 Scottsdale auction, Lot #960 - $80K
Eventually sold by Brighton Motor Sports in Scottsdale, AZ - http://www.remarkablecars.com/ppads/...p/product/4844
Old 12-21-2015, 02:00 AM
MikeNoun's Avatar
I believe John V. would be able to offer more insight into this. I'm not certain, but I don't believe SR would stand for Service Replacement block. I can't imagine why corporate would specify a service replacement block for a car coming down the assembly line. I was comparing different Pontiac plant 1964 GTO build sheets I have, and the ones with the AXLE 39 10 note always have the same message in the Production Instructions.
Old 12-21-2015, 12:21 PM
johns johns is offline
I agree with riggsjr. He makes too much sense. Back in the day when we blew up the original engines, we went back to our local Pontiac dealer, gave him a song and dance about a bad engine and hopefully he'd order a new one from the factory because he had none sitting around, hence the SR. I'm not saying that the original engine was stamped SR, just the "service replacement" engine. Just my 2 cents worth-
Old 12-21-2015, 01:15 PM
MikeNoun's Avatar
Guys, I'm referring to the "SR" on the build sheet only, the topic of discussion here. If an engine needed replacement, then yes, a service replacement block may be used if the engine could not be repaired.
I can't imagine why Pontiac would code a build sheet for a service replacement block on a car that hasn't yet been built?
The AXLE 39 10 APP reference was for 3.90 gears. The only way to get this ratio was with posi and metallic brakes, and those codes are shown in boxes 71P (3.90), 692 (metallic brakes), and 703 (posi).
Mike
Old 12-21-2015, 01:23 PM
Tom Vaught's Avatar
Boost Engineer
Replacement Blocks were supposed to be stamped SR by the Dealer changing the Block.
SR on a manifest typically meant a Special Request or Special Ratio in the 3.90 axle case.
Tom V.
Old 12-21-2015, 02:47 PM
Keith Seymore's Avatar
Mike
This is correct.
At the time the build sheet is printed the car hasn't been built.
K
'63 LeMans Convertible
'63 Grand Prix
'74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/
Old 12-21-2015, 02:48 PM
Originally Posted by gto_ron View Post
Hi all,
Also: Ron - your car was "tagged" for an employee with the last name of "Bolen".
"Tagging" is the means by which an employee had dibs on a car, either because they ordered it or because they were going to receive it after it came out of company car use (either as a development car or a PEP type vehicle).
More famous example shown below.
K
Name:	Tenney BuildSheet.jpg
'63 Grand Prix
Old 12-21-2015, 04:16 PM
Chris65LeMans's Avatar
K
I like the "delete all insulation!"
Old 12-21-2015, 04:48 PM
MikeNoun-You're right, I got off the track-SORRY!
Old 12-21-2015, 07:57 PM
Ron Landis's Avatar
Thumbs up Also...
I see it has the "9" in the tranny box...also for the 3.90 gear speedo drive. Sounds like an interesting car at the very least!
Old 12-31-2015, 01:05 AM
gtoric's Avatar
gtoric gtoric is offline
SR=front springs
PN=rear springs
174=front shocks
175=rear shocks
