Old 12-27-2015, 09:34 PM
67drake's Avatar
67drake 67drake is offline
Default Ford F-350 rear end clunk
My son out in CA called me about this. He has a '99 Ford F350 that has a severe clunk in the driveline when shifting into gear. He said he has a little vertical slop in the pinion (up/down) of the rear end,and some slop in and out of the pinion. Also he has a touch of slop up and down in the slip yoke. I told him if this was a GM rear,for sure it is junk,but-
OK,never having owned,or rebuilt a Ford rear end,I ASSUME this is no good,Correct?
He said he thinks it as a 10.5 rear,if that helps.
Thanks.
‘55 Catalina
Old 12-27-2015, 09:54 PM
Is the big nut tight? Has anyone recently put a pinion seal in?
'68 GTO
'69 Corvette
'75 Cadillac Coupe Deville
TOM
Old 12-27-2015, 10:20 PM
67drake's Avatar
I'd have to ask him about the pinion nut. He just bought the truck not too long ago,so we don't know if the seal has been replaced.
‘55 Catalina
Old 12-27-2015, 11:05 PM
67drake's Avatar
Just talked to him,he said he didn't know if the pinion nut is tight or not,and seeing as how I don't think the Ford has a pinion bearing pre-load/crush sleeve like a GM,I told him not to touch it until I find out more info on the Ford rear end set up.
Thanks for any help.
‘55 Catalina
Old 12-28-2015, 08:38 AM
The Boss's Avatar
The Boss The Boss is offline
Clunk when put in gear can also be the U-joints.
Slop in/out is not good.
And go racin' in the street.
Old 12-28-2015, 09:56 AM
67drake's Avatar
He said U-joints are tight.
I FIGURED the pinion slop was not good,but he said it's maybe just a few .001". Just not a Ford guru on this end.
Thanks Boss.
‘55 Catalina
Old 12-28-2015, 03:53 PM
Simple Man's Avatar
U joints can appear to be tight, and still be a problem. Have they been taken apart, and inspected?
be a simple...kinda man.
Old 12-28-2015, 04:24 PM
66beaumont's Avatar
66beaumont 66beaumont is offline
early 10.5 diff had crush sleeve .had same issue with my 90 f250 sleeve had collapsed,very likely they still use the sleeve. I believe there are kits available to replace sleeve with shims
69 gto ,all#match,467,th400,3:55 Easton posi,resto completed may 2016. 427 hp/530tq. Stump puller with stock#62 , stock intake and qjet
Th400 gone. Tkx close ratio with .64 of
66 Pontiac Beaumont sport deluxe,BB 5sp tko 3:08 auburn 450hp 550 torque wife sold it
Old 12-28-2015, 11:00 PM
Trulyvintage's Avatar
Trulyvintage Trulyvintage is offline
Lightbulb Take it to a mechanic
All I drive are F350 Duallys ...
He needs to take it to a shop that has EXPERIENCE replacing rear differentials.
It is not a " do it yourself " diagnosis or repair.
Jim
Old 12-29-2015, 11:48 PM
John275 John275 is offline
hey gents (said son here),
Thanks for all of the input, ended up getting a new slip yoke from a local driveline shop as part stores couldn't even order the part and that solved the noises, the splines were extremely warn when i separated it due to a lack of grease, so it would bounce all over while coasting
Old 12-30-2015, 09:30 AM
67drake's Avatar
Johnny,I sent you to school for a reason. Always use proper punctuation, grammar,and check spelling.
Glad you figured it out.
‘55 Catalina
Old 12-30-2015, 10:08 AM
haha, I didn't go to colledge for this very reason thanks again.
